broken knock sensor...
Old Apr 4, 2004 | 08:16 PM
codeh22a4's Avatar
Default broken knock sensor...
i have a 99' lude base model with a broken knock sensor and now my vtec isnt working,can it be that the knok sensor is broken????
Old Apr 4, 2004 | 10:12 PM
codeh22a4's Avatar
Default Re: broken knock sensor... (codeh22a4)
can somebody help me with my problem?
Old Apr 4, 2004 | 10:51 PM
blackdelslo's Avatar
yeah im pretty sure you wont hit VTEC with a broken knock
Old Apr 4, 2004 | 11:04 PM
codeh22a4's Avatar
Default Re: broken knock sensor... (delLudeVTEC)
its gotta be that,the vtec wont activate and my car limits like in 6,500 and its runs like crap,i think my moms daewoo runs harder
Old Apr 5, 2004 | 06:12 AM
ensracer's Avatar
i am not running a knock sensor and i hit vtec. i think that you could maybe have another problem.
Old Apr 5, 2004 | 07:02 AM
wstef's Avatar
It depends of ECU firmware version. For exemple the european H22 prelude (ecu code 37820-P13-G00) doesn't have a knock sensor at all. But I suppose if it is a USDM one with knock sensor broken or disconnected you will not engage vtec.
Old Apr 5, 2004 | 08:05 AM
99spanishGT
Guest
Posts: n/a
Default Re: broken knock sensor... (wstef)
yeah i didnt have knock sensor and i hit VTEC
Old Apr 5, 2004 | 08:22 AM
Eddiebx's Avatar
it should still be able to get into vtec w/o the KS, if your vtec aint engaging, you have other issues.
Old Apr 5, 2004 | 10:23 PM
codeh22a4's Avatar
Default Re: (Eddiebx)
nah its gotta be the broken knock sensor
Old Apr 8, 2004 | 12:51 AM
b18cjdmeg6's Avatar
its your knock sensor...vtec wont work without it...or you could pull your knock sensor wire and ground it to the chassis and hook the other end to the ecu. also you can get an ecu that doesn't check for knock sensor.
SingleCamin
May 19, 2009 08:23 AM
cacahead1
Jun 8, 2005 04:41 PM
Brick Top
15
Oct 28, 2004 10:48 PM
Audi A4
Sep 18, 2003 12:03 AM
