compression test results
Old Apr 7, 2004 | 11:47 AM
JetSI's Avatar
Default compression test results
92 Prelude SI 4ws, H23a engine. Cars burns oil bad, inside exhaust coated with oil.Compression test results
1-230
2-230
3-220
4-230
Is compression good and if so whats wrong with engine? Engine has 98,000 miles
Old Apr 7, 2004 | 12:04 PM
Sephro's Avatar
Default Re: compression test results (JetSI)
Those numbers seem damn high for an H23. Are you sure you read it right? not 130 and 120??
Old Apr 7, 2004 | 12:18 PM
JetSI's Avatar
Default Re: compression test results (Sephro)
Did compression test twice on each cylinder. Readings are right
1-230
2-230
3-220
4-230
Old Apr 7, 2004 | 01:10 PM
TimeRacer's Avatar
I'd do it wither another tester, since even my H22 doesn't have compression numbers as high as that.
Old Apr 7, 2004 | 01:22 PM
99spanishGT
Guest
Posts: n/a
Default Re: compression test results (TimeRacer)
you sure enging is stock!!
Old Apr 7, 2004 | 01:27 PM
caLiH22A's Avatar
Default Re: compression test results (spanishlude)
Agreed, those numbers are pretty damn high, my JDM H22A got a best of 225 and that is with the stock 10.6:1 compression.
Old Apr 7, 2004 | 03:00 PM
@ries's Avatar
:scratches head: something doesn't sound right with those #'s.
Old Apr 7, 2004 | 03:02 PM
SKDRCR's Avatar
Default Re: compression test results (emoBB1)
It's probably reading that high do to the carbon buildup.
Old Apr 7, 2004 | 03:13 PM
JetSI's Avatar
Default Re: compression test results (SKDRCR)
what should the #'s be ?
Old Apr 7, 2004 | 03:28 PM
Prelude Styl's Avatar
170-180 range... about
Old Apr 7, 2004 | 04:53 PM
JetSI's Avatar
Default Re: compression test results (Prelude Styl)
Would anything other than carbon buildup cause high compression? Just went out and did another compression test and the #.s came out the same.
Old Apr 7, 2004 | 05:01 PM
junbb1's Avatar
the reason why the numbers are high is due to one that the carbon and oil deposits built up on the pistons. but mainly due to the amount of wet oil in the cylinders. wet oil, aka a wet compression test will drastically change the compression upwards to 30 psi.
a wet compression test is when you put oil intentially into the cylinders on a car with low compression. if the compression raises then you know that the rings are bad.
Old Apr 7, 2004 | 05:36 PM
TimeRacer's Avatar
Default Re: compression test results (junbb1)
Wet compression test deals with piston rings, not the carbon build up.
Old Apr 7, 2004 | 05:57 PM
junbb1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TimeRacer &raquo;</TD></TR><TR><TD CLASS="quote">Wet compression test deals with piston rings, not the carbon build up.</TD></TR></TABLE>
my point exactly. the amount of oil in his cylinders will increase the compression.
snowblind7x
Apr 13, 2005 08:12 PM
Norcalstoppy
Nov 21, 2002 12:55 PM
2old_honda
Apr 12, 2002 01:25 AM
MechEng
Feb 11, 2002 06:15 PM
