hyperground wires...
Old Apr 5, 2004 | 01:30 AM
Inextricabledrvr's Avatar
Default hyperground wires...
are these worth it or are they just a waste of money ?
ive read some peoples reviews and have gotten dufferent results. I wanted to ask you guys if you noticed any power gains?
im sorry guys, but i thought these are a grounding kit that goes from the battery terminal to the car.
thanks
Modified by Inextricabledrvr at 1:24 PM 4/5/2004
Old Apr 5, 2004 | 02:27 AM
jc836's Avatar
Default Re: hyperground wires... (Inextricabledrvr)
Is anyone aware that heavier ground cables will do very little for "power gains". The most they can do is reduce some of the load on the Alternator-and that won't be much either. Honda is very good at engineering electrical systems. The only benefit of heavier wire will be when you have a massive stereo and an alternaotr and battery that needs the added amperage capacity.
SAVE you money for something more important.
Old Apr 5, 2004 | 04:54 AM
doucmehu's Avatar
Default Re: hyperground wires... (jc836)
I agree, it's kind of a waste of time. If you ar ran out of mods (haha yea right), or most importantly have a huge system, go for it. Otherwise it seems like it is mostly for show.
Old Apr 5, 2004 | 05:25 AM
Daboi630's Avatar
check my dyno in my sig.
Old Apr 5, 2004 | 08:27 AM
LudeyKrus's Avatar
They're a waste of money.
If you NEED a new set of wires, then get some NGK's.
Old Apr 5, 2004 | 08:29 AM
Daboi630's Avatar
i have NGK's too! and the wires were a gift, i wouldnt have gotten them if i had to pay for it. i would save up for cams
Old Apr 5, 2004 | 11:47 PM
Vp Special K's Avatar
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">They're a waste of money.
If you NEED a new set of wires, then get some NGK's.</TD></TR></TABLE>
i thought he was talking about hyperground ground wires?
Old Apr 6, 2004 | 07:33 AM
LudeyKrus's Avatar
Default Re: (Vp Special K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vp Special K &raquo;</TD></TR><TR><TD CLASS="quote">
i thought he was talking about hyperground ground wires?</TD></TR></TABLE>
Whoops! Wrong wires!
They're still a waste of money. Dynos have shown that they give little to no horsepower gains. There ARE a few cars that do respond a bit to them, like the WRX, because they have a poor grounding system from the factory, but not ours cars.
Old Apr 6, 2004 | 09:58 AM
Sephro's Avatar
I agree that the kits are a waste. Sometimes when you do engine swaps you might need more grounding. Grounding better will help sensors get a more accurate reading.... But more power, I doubt.
Old Apr 6, 2004 | 12:05 PM
Default Re: (Sephro)
sorry for about the lack of info on my part. thanks guys for the info.
Old Apr 6, 2004 | 01:07 PM
b16hybridsol's Avatar
Default Re: (Inextricabledrvr)
honda did do a good job on eletrical stuff, the hyper ground is a waste on hondas. I added a couple when i did my swap for the hell of it but it was spare wire. I've seen some messed up stuff from bad grounds though, on other cars at school. When you have bad grounds your motor trys to ground through whatever possible, so after a while it can mess up rubber bushings, seals, etc.. If its really bothering you, get the multimeter out and test your ground wires, or just add some wires ha, its not going to hurt anything but your wallet
Old Apr 6, 2004 | 03:41 PM
TimeRacer's Avatar
Default Re: (b16hybridsol)
I got bored and did a "homebrew" version of it for $20 with 8 and 4 gauge audio wire. Didn't feel a damn bit of difference, though in total it was a 1 hour project. So I don't think it took too much from my life.
ryanangelo212
Apr 27, 2013 07:43 PM
Rajinazn06
17
Mar 23, 2008 07:44 PM
qazaq
Nov 9, 2006 03:36 PM
slvrcivic97
15
Jul 21, 2003 02:03 PM
travis
Jan 21, 2002 09:29 PM
