help, jack stand placement
Old Apr 9, 2004 | 11:00 AM
mv10s's Avatar
Default help, jack stand placement
if i use a hydraulic floor jack under the "factory jack pads", (front of rear wheels and behind front wheels) to raise the car, where would i place the jack stands for support and safety? in the rear i use the floor jack under the crossbeam between the two rear wheels then place the jacks in the factory jack pads. not sure about the front. how do i raise it and where do i place the jacks?
thanks
Old Apr 9, 2004 | 11:02 AM
jc836's Avatar
Default Re: help, jack stand placement (mv10s)
Pick up the front under the center Tow Hook and then place the stands under the jacking points on the sides. The rear can be picked up either under the center of the subframe or under the tow hook-put stands under side jacking points. That is what we do.
Old Apr 9, 2004 | 11:29 AM
RCautoworks's Avatar
Default Re: help, jack stand placement (jc836)
Jack the car up by the frame, the car will get the most height this way. Angle the jack so its not in the way for the jackstand to be placed on the pinch weld metal spot.
Old Apr 9, 2004 | 11:40 AM
OTT's Avatar
OTT
If your looking at the jacking points at the front, put the Hydraulic Jack right under the car behind the jacking points where the frame petrudes from the body of the car. Then with the at an angle (not directly facing the car) you can jack the car up and put the axle/Jack-stands at the normal jacking points.
But dont ever put the car on more than 2x axle-stands, if you put it on 4, i.e. completely off the ground then just leaningon the car could cause it to twist enough and fall off of the stands.
Always 'chok' the wheels that are still on the ground and you should put an old wheel under the car to one side just behind the jack stands. If your working under a 1300kg lump of metal balanced on some jack stands you should never take any chances, its your fate your messing with
What are you doing to the car anyway?
Old Apr 9, 2004 | 12:46 PM
mv10s's Avatar
Default Re: (OTT)
i will be replacing rear shocks this weekend. exhaust next week. thanks and happy "good friday" to all
Old Apr 10, 2004 | 03:59 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: (mv10s)
when your car is on the stands, try rocking it a bit. if it doesn't budge or fall off the stands, you will be fine.
98y8
Oct 7, 2009 09:04 AM
Whatislove
Honda Civic (2001 - 2005)
16
Jun 17, 2009 08:11 AM
b16egsi
Oct 27, 2003 11:45 AM
MCP486
Jan 20, 2003 03:52 PM
Zulu888
Aug 20, 2002 02:47 PM
