Prospeed Header installed
Old Apr 1, 2004 | 07:07 PM
Shakes's Avatar
space cadet
Default Prospeed Header installed
ok, after a ton of problems i finally got the damn thing installed.
it took a lot of work and still has more work to come. here is what i had to be done/has to be done to make this fit an SH. it is fitted on an H22a/a1.
leingthen after (downwards) the collector to stop it from rubbing on the oil pan.
adjust it so that when leigthened it wont rub on the side (could be due to my own fault, not really sure. i tried welding it myself and had never done it before.)
for a base model leave the DP the same leingth. for an SH extend it about 4 inches. have the exhaust/customizing shop do that.
pull out drivers side fan to get it in, then re install it.
clears AC and cross member.
as it is now running open header it is loud as ****! sounds like a camaro SS running straight pipes if not worse. once i get it all hooked up to the exhaust it should be better. but right now OMFG is it sweet!
should fit a 4th gen no problem as far as i can tell.
Special thanks goes out to Adam at VAcustoms (www.vacustoms.com) for dropping his work to help me out when he had never even met me before!
Modified by shakes at 12:19 AM 4/2/2004
Old Apr 1, 2004 | 07:10 PM
FlaN.'s Avatar
Default Re: Prospeed Header installed (shakes)
Old Apr 1, 2004 | 07:12 PM
Shakes's Avatar
space cadet
Default Re: Prospeed Header installed (FlaN.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlaN. &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
come on mang, lets hit the strip lol
Old Apr 1, 2004 | 07:13 PM
FlaN.'s Avatar
yea, and i'll tape your *** getting pulled over!
Old Apr 1, 2004 | 07:14 PM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlaN. &raquo;</TD></TR><TR><TD CLASS="quote">yea, and i'll tape your *** getting pulled over! </TD></TR></TABLE>
boring, tape the arrest
Old Apr 1, 2004 | 07:15 PM
Kendall's Avatar
I'm glad to see it in and running. Do you have any pics of the modifications?
Old Apr 1, 2004 | 07:17 PM
Shakes's Avatar
space cadet
Default Re: (Kendall)
not yet. i still have to take it out and coat it. im going to use black 1200 degree ceramic paint.
Old Apr 1, 2004 | 07:37 PM
satan_srv's Avatar
Default Re: (shakes)
it just ends at the oil pan?
Old Apr 1, 2004 | 07:41 PM
Shakes's Avatar
space cadet
Default Re: (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">it just ends at the oil pan?</TD></TR></TABLE>
there is a downpipe that attaches to that. extends it out to stock location for a base model.
Old Apr 1, 2004 | 07:55 PM
Daboi630's Avatar
DYNO DYNO DYNO DYNO
Old Apr 1, 2004 | 07:56 PM
Shakes's Avatar
space cadet
Default Re: (Daboi630)
later this month i will be going to sams in NC passing by Jdoggs shop. so if his offer is still open then i will dyno it there on my way down.
Old Apr 1, 2004 | 11:17 PM
ludeR917's Avatar
how you get to those bolts under the header?
Old Apr 2, 2004 | 01:26 AM
disabled's Avatar
looks good i like it , wonder how much power will it make, haha open header
Old Apr 2, 2004 | 02:35 AM
Shakes's Avatar
space cadet
Default Re: Prospeed Header installed (ludeR917)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludeR917 &raquo;</TD></TR><TR><TD CLASS="quote">how you get to those bolts under the header?</TD></TR></TABLE>
its not the easiest thats for sure, but it can be done. just have to go old school and use a open end wrench.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">WoRsT tHrEaD eVaR!!!!!!</TD></TR></TABLE>
go play with your intake manifold
Old Apr 2, 2004 | 04:04 AM
Crate's Avatar
looks like a mess to deal with. hope it gets some decent gains. =]
Old Apr 2, 2004 | 05:55 AM
Jason kiDD's Avatar
Default Re: (Crate)
Good stuff.. Hope to get dyno'd soon with my setup.. Will post up the numbers when I am done..
Old Apr 2, 2004 | 07:01 AM
Krnbk2's Avatar
is that the mild steel version? if so, are you planning on coating it?
Old Apr 2, 2004 | 08:16 AM
Shakes's Avatar
space cadet
Default Re: Prospeed Header installed (krnbk2)
yes it is mild steel. i will be coating it with 1200 degree exhaust paint.
Old Apr 2, 2004 | 09:01 AM
Greyout's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shakes &raquo;</TD></TR><TR><TD CLASS="quote">as it is now running open header it is loud as ****! sounds like a camaro SS running straight pipes if not better</TD></TR></TABLE>
Old Apr 2, 2004 | 09:09 AM
Jagan'92's Avatar
Congrats on getting your car on the road after 2.5 weeks of downtime.
Learn to weld!
Old Apr 2, 2004 | 09:10 AM
Shakes's Avatar
space cadet
Default Re: Prospeed Header installed (Greyout)
no i have to say worse because the 2 mile drive home last night from the shop gave me a splitting headache all night. well, that and doing a couple 80 mph WOT runs for Kendall and Peter didnt help any. but tomorrow i have to find an exhaust shop to bend that pipe a bit more and then measure the rest out and weld another pece on there. so more money into this project that i didnt expect to spend.
Old Apr 2, 2004 | 09:47 AM
94vtecmn's Avatar
Sounds like a major pain in the ars to get it mounted and hooked up properly. Poor design in my opinion......
Old Apr 2, 2004 | 10:23 AM
Shakes's Avatar
space cadet
Default Re: Prospeed Header installed (94vtecmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94vtecmn &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a major pain in the ars to get it mounted and hooked up properly. Poor design in my opinion......</TD></TR></TABLE>
it wasnt originally designed for the lude. it was originally made for H22 swaps into Civic's.
Old Apr 2, 2004 | 01:29 PM
Crate's Avatar
ya. i'm just gonna get a full-race manifold. and all the rest of the parts that go too prolly. ;]
Shakes: if you know anyone in the area that wants a jdm h22 head. complete and in very good conditoin. w/ intake manifold, tb, sensors and all. let me know.
Old Apr 2, 2004 | 01:46 PM
fast4w$'s Avatar
Default Re: (Crate)
Awesome header...but why does the last pic of the collector seem to be only like 2" max when you'd think it'd be a bit larger? Either way, nice job squeezing it a 5th gen.
btw, Is Prospeed in Va?
