Clutch problem
Old Apr 9, 2004 | 10:28 PM
92LudeSI's Avatar
Default Clutch problem
Ok heres my deal. I put in an Exedy clutch about oh maybe 10k at most miles ago. It was nothing special just like a stock clutch. I have 178K on the motor and I got in a hurry putting it back together because it is my only car and the weekend was ending quickly so I didnt get the flywheel resurfaced. Now the clutch is slipping. Its weird thou I did the highway test 50 in 5th gear and that was fine. It dies if i try strating off in third. and it stil grabs hard going into 3rd and somtimes it will tear them apart going into second and then some times if I jsut punch it in first the prms jsut spike. WTF Do you think this could be a result of the flywheel or jsut a cheap exedy clutch. Sorry for the paragraph
Old Apr 10, 2004 | 12:54 AM
Variable J's Avatar
Default Re: Clutch problem (92LudeSI)
Sounds like you might have a bad igniter. Its a part of your distributor. Inside.
Old Apr 10, 2004 | 06:21 AM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92LudeSI &raquo;</TD></TR><TR><TD CLASS="quote"> Do you think this could be a result of the flywheel or jsut a cheap exedy clutch. Sorry for the paragraph </TD></TR></TABLE>
Exedy??? Cheap??
Exedy has a great reputation. In fact, they make OEM clutches for AMNY manufacturers. There is a reason why they have a good reputation.
Old Apr 10, 2004 | 07:06 AM
92LudeSI's Avatar
Is what i meant by cheap was the one i got was cheap I know exedy does make good clutches. As far as the ignighter that was all replaced last summer. The entire distributer went bad and was replaced.
Old Apr 10, 2004 | 01:02 PM
SKDRCR's Avatar
Default Re: (92LudeSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92LudeSI &raquo;</TD></TR><TR><TD CLASS="quote">Is what i meant by cheap was the one i got was cheap I know exedy does make good clutches. As far as the ignighter that was all replaced last summer. The entire distributer went bad and was replaced. </TD></TR></TABLE>
the ignitor doesn't some with the distributor if you replace the dizzy
Old Apr 11, 2004 | 08:20 AM
92LudeSI's Avatar
ok now I know there are alot of things that can affect the way your car runs on certain days but coudl this affect why sometimes it feels sluggish and some days pretty quick?
Old Apr 11, 2004 | 11:56 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92LudeSI &raquo;</TD></TR><TR><TD CLASS="quote">ok now I know there are alot of things that can affect the way your car runs on certain days but coudl this affect why sometimes it feels sluggish and some days pretty quick? </TD></TR></TABLE>
i think if it was a result of your flywheel not being resurfaced,
it wouldn't be an on off thing.
Old Apr 11, 2004 | 12:20 PM
AKUFC's Avatar
Default Re: Clutch problem (Variable J)
How does the igniter affect the clutch slipping?
Old Apr 11, 2004 | 12:29 PM
piotrush's Avatar
Default Re: Clutch problem (AKUFC)
Pentaq told me he went throught 3 clutches (one of which was exedy) within some ridiculously short period of time because his flywheel had tiny cracks in it - so it could very well be related to the flywheel causing it.
mike93eh2
Nov 8, 2006 04:34 PM
SpOoNisMyFriEnD
May 11, 2005 02:18 PM
yellowctr97
Feb 23, 2005 04:22 PM
dohcnotec
Jul 20, 2004 11:36 AM
onyx00
Mar 19, 2004 09:10 PM
