Clutch Dampener? How does it work?
Old Apr 7, 2004 | 09:52 PM
jdmcivicferio's Avatar
Default Clutch Dampener? How does it work?
How does this clutch dampener work?
Does it add more fluid to the clutch system?
Will it make the pedal feel softer?
Is it better for a car with a stronger clamping force?
the more information the better
thanks guys!
Old Apr 8, 2004 | 08:41 AM
flyrod's Avatar
Default Re: Clutch Dampener? How does it work? (jdmcivicferio)
That picture is not of the clutch damper, that's just a hard mount to hook the steel hydraulic line to the flex line banjo fitting. I don't know how the damper works exactly, but I think it is just for vibration or "feel." For example I don't think the ITR or NSX-R has one. It probably has some precision orifices or valving inside it.
Old Apr 8, 2004 | 11:18 AM
s2kkid's Avatar
hey dude, thats just a Metal joint.
The joint bolts on your transmission, where us see that bolt, thats where a rubber hose attaches coming from the dampener. The metal line you see, heads towards the slave cylinder.
Old Apr 8, 2004 | 06:50 PM
lunarcry's Avatar
this is a damper
Old Apr 11, 2004 | 05:10 PM
Default Re: Clutch Dampener? How does it work? (lunarcry)
so the prelude has a cluch dampener? how exactly does it work, is fluid being added into there almost like a resovoir?
Old Apr 12, 2004 | 07:45 PM
anyone?
Old Apr 13, 2004 | 11:28 AM
flyrod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio &raquo;</TD></TR><TR><TD CLASS="quote">how exactly does it work, is fluid being added into there almost like a resovoir?</TD></TR></TABLE>
What 'exactly' are you trying to do? Like I said, it probably has some precision orifices or valving inside it, like any hydraulic damper. I read in one place that honda uses a damper on some cars do slightly delay clutch engagement to improve clutch feel, drivability, and clutch life. So it probably has a one way valve with an orifice with a specific diameter, so that you can quickly disengage the clutch but it re-engages at a controled rate. It may also have a gas backed diaphram to reduce vibration transmited to the clutch pedal.
So, bottom line: if you don't have one, you probably don't absolutely need it. If you have one and are trying to save every ounce, you can probably ditch it. For more than that, you can grab one at a junkyard and take it apart to see how it works...
Old Apr 13, 2004 | 02:15 PM
Default Re: Clutch Dampener? How does it work? (flyrod)
I have a civic with a h22 in it, and the civic master cylinder is to weak, so I upgraded to a prelude master cylinder, but I was wondering how the damper worked to see if it added fluid in because the pressure plate I have for the car is a 2500psi pressure plate, which makes short life of the hydrolic system, so my theory is if it is an added resovoir of fluid it would benefit my setup and add the additional fluid to help press down the pressure plate, thanks for the help
sl0whatch
Jun 13, 2010 01:00 PM
LOWLIFEHATCH
Mar 24, 2006 03:35 PM
jdmludeturbo
Feb 20, 2006 07:18 PM
InTeGrA_bLazEd
Mar 28, 2005 08:19 AM
boomslang
Nov 23, 2001 02:16 AM
