CUTTING THE SHIFTER!
Old Jul 21, 2004 | 06:39 AM
Draven_Von's Avatar
Default CUTTING THE SHIFTER!
hey experts, i'm trying to shorten my shifter... but i'm trying to find the correct size tap and die as suggested, 10mm,11mm,12mm all 1.50... where the heck can i find this thing...? i've been to the local places like home depot... they don't have anything! help?
Old Jul 21, 2004 | 06:47 AM
Kal's Avatar
Kal
Default Re: CUTTING THE SHIFTER! (Draven_Von)
look at http://www.ntpog.org
they have a writeup about shortening the shifter...not much use to shorten though.
Old Jul 21, 2004 | 07:10 AM
Draven_Von's Avatar
Default Re: CUTTING THE SHIFTER! (Kal)
oh?
why is it no use?
i'm also putting one of those adaptors on it to shorten the throw.
i'm followiing their directions actually... but i'm just having problems finding the correct tap and die size.
Old Jul 21, 2004 | 07:23 AM
93H22ACX's Avatar
you dont need to cut the shifter. just buy a greddy shift **** and it'll lower everything
Old Jul 21, 2004 | 08:47 AM
98TypeSH's Avatar
Default Re: CUTTING THE SHIFTER! (93H22ACX)
spoon shift **** works pretty good. I was also thinking of cutting mine till i put that bad boy on there and it was low enough for me.
Old Jul 21, 2004 | 08:49 AM
93H22ACX's Avatar
Default Re: CUTTING THE SHIFTER! (98TypeSH)
tight
Old Jul 21, 2004 | 09:06 AM
bad-monkey's Avatar
i had a small shift **** on my car, setup low, but i just got a new one that sits up higher (making the shifter longer in essence) and it's so much nicer to have that extra few cm of moment arm to get through the gears.
Old Jul 21, 2004 | 05:44 PM
foshizllmynizl's Avatar
Default Re: CUTTING THE SHIFTER! (bad-monkey)
nah but still ... ive tried to locate thoose dies according to the write up ... and its damn near impossible to find including internet untill you buy a complete tap and die set for like a 100 bucks ... so any one know where to purchast thoose????
Old Jul 21, 2004 | 05:55 PM
eLUDEnu
Guest
Posts: n/a
Default Re: CUTTING THE SHIFTER! (foshizllmynizl)
cheap beaaatches!!!!!!!! Buy a damn short shifter and a skunk 2 ****
Old Jul 21, 2004 | 06:47 PM
clemsoncb7's Avatar
Dudes, you don't need to buy a die and all that crap. Do what I did and weld it. Cut out a piece in the middle and weld the two remaining pieces back together. It gives you a clean look and you can keep the threads and not have to worry about the stupid die. If you cannot weld, just find a local welder and he should do it for really cheap. Hope this advice helps
Old Jul 21, 2004 | 07:01 PM
7808's Avatar
Default Re: CUTTING THE SHIFTER! (maxvtec7500)
buy tap kit use it and return it.. or rent one.. or find someone who has one u can barrow.. damn be resourceful
Old Jul 21, 2004 | 07:46 PM
hOndafienD 04's Avatar
cut the shifter and weld a bolt onto the shifter that threads into the ****....true short shifter...i just completed mines today and would recommend any1 to do this
Old Jul 21, 2004 | 08:56 PM
Monkey Fing a Coconut's Avatar
Default Re: (hOndafienD 04)
if this is for a 4th gen, honestly 4bidden is the way to go, i tried cutting mine and it was crap compared to 4bidden....for 5th gen i guess u gotta cut it til a true ss becomes avail
Old Jul 21, 2004 | 10:20 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: (twistedbydezign)
there is a true short shifter here http://www.leanracing.com/shifter.htmthis is the best way to go in looks and funktion but it is kinda pricey
Old Jul 21, 2004 | 10:36 PM
matix's Avatar
Default Re: (raylude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxvtec7500 &raquo;</TD></TR><TR><TD CLASS="quote">Dudes, you don't need to buy a die and all that crap. Do what I did and weld it. Cut out a piece in the middle and weld the two remaining pieces back together. It gives you a clean look and you can keep the threads and not have to worry about the stupid die. If you cannot weld, just find a local welder and he should do it for really cheap. Hope this advice helps </TD></TR></TABLE>
I did the same thing it took like 30 mins to do. I also got the short shifter adapter making it effective.
Old Jul 21, 2004 | 10:38 PM
five-0's Avatar
I've had mine cut pretty short for a while now and have nothing bad to say about it. It is aesthetically pleasing. I get into ludes with the stock heighth shifter and it seems wrong... all wrong.
Old Jul 21, 2004 | 11:07 PM
fastludeh22's Avatar
Default Re: (five-0)
http://www.forbiddenmotorsports.com/
search memeber 4bidden he maks them. i think a 5th gen one is comming out. the best from what ive heard
Old Jul 22, 2004 | 11:28 AM
Default Re: (fastludeh22)
nah ... i pmd 4bidden about the 5th gen shifter ... there arnt any plans for the near future ... but i WILL look into that welding idea(dont feel like paying 150 for a lean one) ... thnks guyz ... pece
Old Jul 22, 2004 | 11:42 AM
93H22ACX's Avatar
Default Re: (foshizllmynizl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foshizllmynizl &raquo;</TD></TR><TR><TD CLASS="quote">nah ... i pmd 4bidden about the 5th gen shifter ... there arnt any plans for the near future ... but i WILL look into that welding idea(dont feel like paying 150 for a lean one) ... thnks guyz ... pece</TD></TR></TABLE>
why not just buy the greddy shift **** like i said? it'll drop the length low enough.
Old Jul 22, 2004 | 01:43 PM
kotetu's Avatar
Default Re: (93H22ACX)
Anyone who's going to be cutting and welding their shifter, PM me if you want a spare one to do it on. You don't want to screw up your only shifter, and this way you get less downtime.
Old Jul 22, 2004 | 02:14 PM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedbydezign &raquo;</TD></TR><TR><TD CLASS="quote">if this is for a 4th gen, honestly 4bidden is the way to go, i tried cutting mine and it was crap compared to 4bidden....for 5th gen i guess u gotta cut it til a true ss becomes avail</TD></TR></TABLE>
I agree. 4bidden has been good for me.
Old Jul 22, 2004 | 05:26 PM
hey man...if you dont wanna spend the money for the forbidden shifter and want it to be real low and shifts real short...do it yourslef......just cut it...no need to pay 200 suntin bux for something you can do for free!
Old Jul 22, 2004 | 05:41 PM
4bidden's Avatar
Its $125, not $200
Old Jul 22, 2004 | 05:51 PM
SKDRCR's Avatar
Default Re: (4bidden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden &raquo;</TD></TR><TR><TD CLASS="quote">Its $125, not $200 </TD></TR></TABLE>
$125 awesome not a bad price for good quality
Old Jul 22, 2004 | 06:00 PM
ok ok...dat is a pretty good price.....but id rather do the same for free...thats just me...but props to your shifter...
