Brake lights
Old Jul 17, 2004 | 02:32 PM
JDMSloLude's Avatar
Default Brake lights
I am having a problem with my 94 Prelude. My brake lights do not work and there are no blown fuses. What makes this even more weird is that my back up lights, turn signals, and the lights that come on with the headlights all work. Just the brake lights are failing.
Someone smashed my taillights in with a hammer, but I still dont see how that is causing the brake lights to fail now???
Any help is as always appreciated.
-Ryan
Old Jul 18, 2004 | 07:04 AM
JDMSloLude's Avatar
Default Re: Brake lights (JDMSloLude)
bump
Old Jul 18, 2004 | 07:57 AM
jdm22vtec's Avatar
do the tail lights turn on when you put the headlights on or is it just your brakelights?
If you checked fuses and everything i would think it might have something to do with that sensor thingamajig under your brake pedal.... but thats just a guess
Old Jul 18, 2004 | 09:33 AM
JDMSloLude's Avatar
Default Re: Brake lights (jdm22vtec)
Yea when I turn the headlights on and use the turn signals al the lights work. Its just when I hit the brake they dont work.
The manual lists fuse #41 under the hood as the fuse for the brake. Is there another fuse that is connected to the brakes? Also I dont even know which fuse is #41, the numbers are different in the diagram I have??
Thanks
lilyellowrex
Apr 18, 2015 06:20 PM
evol_crx_si
Apr 29, 2007 03:08 PM
cpuff
Oct 23, 2006 12:33 PM
crystalclear444
May 9, 2004 12:36 PM
FullMetalJacket
12
Apr 29, 2003 10:07 AM
