STR throttle body vs bbk
Old Jul 20, 2004 | 10:07 AM
LudeAchris2001's Avatar
Default STR throttle body vs bbk
anybody use one of these on a 5th gen prelude with just I/H/E which brands better...What Size is best to go with 68mm 70mm? what kind of power gains did you get?? need help!
Old Jul 20, 2004 | 10:36 AM
98TypeSH's Avatar
Default Re: STR throttle body vs bbk (LudeAchris2001)
throttle body is only recommend on highly built motors. dont just have I/H/E and a throttle body, it wont net you anything. i would also recommend having the IM Port matched. 70MM should be sufficient depending on how modified we are talking.
Old Jul 20, 2004 | 01:02 PM
satan_srv's Avatar
Default Re: STR throttle body vs bbk (98TypeSH)
pretty sure if they are both CNC machined it doesn't really matter...they pretty much do the same thing...
Old Jul 21, 2004 | 02:33 PM
I was gonna go with a 68mm....Just want to talk to someone who installed one first
Old Jul 21, 2004 | 02:50 PM
All-Motor H22A's Avatar
Is there any formula for determining the optimal opening?
For example: My goal is to get 220WHP All-Motor. What would be optimal size?
I like a stock looking motor, so I was planning to get a stock one bored out to 66mm, but I'm not sure if that's still too small.
Old Jul 27, 2004 | 01:08 PM
AMS MIKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">throttle body is only recommend on highly built motors. dont just have I/H/E and a throttle body, it wont net you anything. i would also recommend having the IM Port matched. 70MM should be sufficient depending on how modified we are talking.</TD></TR></TABLE>
H22 in a eg stock coupe
Intake/header/Exhaust 14.0 on street tires pass after pass at the track
Intake/header/Exhaust and 70mm T/B 13.6 on street tires pass after pass at the track!
Prelude motors LOVE air!!! More air, more fuel the computer will add and more power!
Yes T/B make a difference on I/H/E
Space ***** can bore out a stock T/B
JG makes a nice T/B and so does BBK
Old Jul 27, 2004 | 06:15 PM
Eddiebx's Avatar
Default Re: STR throttle body vs bbk (AMS MIKE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMS MIKE &raquo;</TD></TR><TR><TD CLASS="quote">
i have a friend that runs 13.7 all day long on a completely stock h22 in an eg, with 17s and street tires. so i doubt its the throttle body.
fact is i've dyno tested a stock 60mm tb against a 64mm tb and i gained ZERO horsepower, , and the IM was already port matched for the 64mm i just slapped the stock 60 back on on one pass and low and behold zero hp gain.
Old Aug 2, 2004 | 04:45 PM
Shelton's Avatar
Default Re: STR throttle body vs bbk (Eddiebx)
Spaceballs... he does a really nice job
Old Aug 5, 2004 | 03:02 PM
Default Re: STR throttle body vs bbk (Shelton)
Does BBK 70mm Part Number BBK-1547 work on our H22As?
Old Aug 5, 2004 | 03:09 PM
TonyStarkz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">
fact is i've dyno tested a stock 60mm tb against a 64mm tb and i gained ZERO horsepower, , and the IM was already port matched for the 64mm i just slapped the stock 60 back on on one pass and low and behold zero hp gain.</TD></TR></TABLE>
I think what he is saying is that is 1/4 time decreased from a consistent 14.0 to a 13.7 w/ the new throttle body. He is not saying that it will make you definately run 13s just that it will increase power.
Old Aug 11, 2004 | 06:14 PM
cpforyou's Avatar
Default Re: STR throttle body vs bbk (All-Motor H22A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All-Motor H22A &raquo;</TD></TR><TR><TD CLASS="quote">Does BBK 70mm Part Number BBK-1547 work on our H22As?</TD></TR></TABLE>
I'm wondering the same thing. Some people say that use BBK Throttle Bodies on their Preludes, but on their website:
1546 - 62mm Honda Performance Throttle Body 1.5/1.6L
1547 - 70mm Honda/Acura Performance Throttle Body 1.8L/1.6L
1752 - 70mm Integra GSR Dual-Cam VTEC Throttle Body
1753 - 70mm 1996-2001 Integra Type-R Throttle Body
Which one is it?
Old Aug 11, 2004 | 09:11 PM
stRodda's Avatar
Default Re: STR throttle body vs bbk (cpforyou)
yea, ive heard that too. my friends at the shop say a b-series tb will fit on a h manifold... but im gonna doulbe check before i go and buy one.
Old Aug 12, 2004 | 08:31 PM
VSBB6's Avatar
Default Re: STR throttle body vs bbk (stRodda)
I have heard the BBK ITR TB will fit Prelude. Can someone clarify??
How big is the opening at the IM side of the BBK?
Old Aug 14, 2004 | 08:55 AM
VSBB6's Avatar
Default Re: STR throttle body vs bbk (VSBB6)
Has anyone fitted the BBK ITR 70mm TB on their lude?
Old Aug 16, 2004 | 11:31 AM
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VSBB6 &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone fitted the BBK ITR 70mm TB on their lude?</TD></TR></TABLE>
Old Aug 16, 2004 | 04:08 PM
mt23vtecbb2's Avatar
i just put a 70mm str on mine. it is built and i can tell a nice difference in it.
Old Aug 16, 2004 | 07:53 PM
coil222's Avatar
B series TBs do fit on our cars..
i when I sent mine out to be bored by RC I drove my lude around w/ an integra GSR TB.
Old Aug 16, 2004 | 07:56 PM
VSBB6's Avatar
Default Re: (coil222)
These are the TB that BBK offer for Honda/Acura, does that mean all of their 70mm TB fits Prelude?
Old Aug 16, 2004 | 08:13 PM
Mr.Dew's Avatar
Yep, it's Eric.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coil222 &raquo;</TD></TR><TR><TD CLASS="quote">B series TBs do fit on our cars..
i when I sent mine out to be bored by RC I drove my lude around w/ an integra GSR TB.</TD></TR></TABLE>
I was also wondering the same thing.. thanks for the heads up on that.
Old Aug 16, 2004 | 08:37 PM
BDL IND's Avatar
Default Re: (oNeMoBB1)
All parts are not created equally. We really did our homework on this part and will soon be releasing it for the S2000 and K Series motors. We use high quality parts during assembly, and coat all parts used such as the shaft and spring, to ensure a lasting part.
Just In Case:
If you have a TB that does not have a coated shaft or spring, send it back and we will replace the parts at no charge.
If you have any questions PM me I will try to help you as best I can.
STR
Scott Miller
Old Dec 24, 2004 | 11:29 AM
cpforyou's Avatar
skipper_red
Honda Civic (2006 - 2015)
Nov 3, 2009 12:28 AM
LU
Nov 10, 2006 10:54 PM
LagunaSecaEG
Aug 6, 2006 06:14 PM
Don Jefe
Dec 24, 2005 11:31 AM
cjames235
Welding / Fabrication
Feb 3, 2005 05:36 PM
