cambers question
Old Nov 14, 2004 | 07:44 AM
digitalh3lix's Avatar
Default cambers question
if i was to put in new springs and i had to adjust the cambers kit thats on my car rite now, is there a special took i need to get the right angle degrees? and if i do where can i get and what is it called?
Old Nov 14, 2004 | 11:24 AM
ghost SHell's Avatar
Default Re: cambers question (digitalh3lix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitalh3lix &raquo;</TD></TR><TR><TD CLASS="quote">if i was to put in new springs and i had to adjust the cambers kit thats on my car rite now, is there a special took i need to get the right angle degrees? and if i do where can i get and what is it called?</TD></TR></TABLE>
After you put your new springs in, you should go to an alignment shop. They will correctly alignment your wheels to the rights angle degree using a machine. The machine digitally reads your negative camber. Trying to do this yourself might result in uneven tire ware and bad handling.
Eg6xCiViCxSi
Suspension & Brakes
Feb 25, 2008 12:27 PM
LS1powered
May 24, 2007 04:07 PM
arnold1980
Feb 23, 2005 03:55 PM
crj_lll
Sep 18, 2003 05:14 AM
binkster
Apr 11, 2003 02:59 PM
