prelude Si gauge question
I was just curious after swapping an H22 into my 92 Si will the tach be still reading the right RPMS or will it be off some? If its off would i be able to replace the gauge faces with prelude VTEC gauges which are a little different? Would these ones read correctly or should i just stick with the Si gauges? I noticed the redline on the H22 is much higher than what the H23 is but i wasnt sure if it read the RPMS correctly. Any input would be appreciated.
