5th gear and reverse
Old Nov 11, 2004 | 07:43 PM
prelude994e's Avatar
Default 5th gear and reverse
I did a search guys and found out some good info but i want to get this clarified before i make assumptions.
On way home from tune shop today, happy as could be and cruisin in 5th, my shifter just popped outta 5th completely, put it back in hit the throtle a bit, same thing, so then i began holding it, and felt it pushing into my hand, but only when i was on the throttle a little harder than normal. So a few downshifts to passa some trucks and i eventually hit a point where my holding it cannot stop it from poppin, so i cruised in 4th at 60 for liek an hour
so try one more time, and i feel somehtin bounce up and hit my feet, and i look in rearview mirror to see sumin small bouncing away....?
Finally reach my destination and my car will not go in to reverse, like there is a wall blocking me.
All other gears work fine....just those two, did i mess up some syncos, bent a shift fork? i have no idea and i need a 5th gear for interstate driving as well as reverse so i can park ASAP, should i get a new tranny asap, or is it a cheap fix??
PS: anyone near baltimore, know how to fix trannies or know someone?? thanks
Old Nov 11, 2004 | 08:06 PM
accord387's Avatar
you probably hit somthing, nothing came out of your tranny or your **** would be uber screwed. Sounds like the 5th/reverse shift fork to me, no clue on cost, but i know i have a tranny that i need to fix also. so tell us costs hehe
Old Nov 11, 2004 | 09:46 PM
PrettyLude's Avatar
it is not a cheap fix, the money you spend to fix it you would be cheaper finder a used tranny.
when it happened to me, it cost 1000, but luckily the car still was still under warranty
Old Nov 12, 2004 | 12:14 PM
accord387's Avatar
why? did that include having them take the trany off, fix it and then put it back on?
Old Nov 12, 2004 | 02:53 PM
Default Re: (accord387)
im guessing so, i heard from smaller shop at home that most places, whether they do tranny therer, or send it to another shop are going to try their best to wanna pull the tranny so you run into labor costs of close to a thousand for some......in my case thats what is probably goign to have to happen, but thre are other things a tranny place can check first before they have to pull the unit..............
i guess i was juts unlucky.....
ps: forks go from 30-55 depending on which one
Old Nov 12, 2004 | 08:24 PM
Default Re: (prelude994e)
anyone know where i can get my tranny looked at/ fixed in Baltimore besides
AAmco, or does any of fellow members got a house and some tools near by that wouldnt mind helping me out
SkiLLzWheeLz
Feb 6, 2012 11:27 AM
bullittsvt
Honda Civic (2006 - 2015)
Nov 29, 2008 07:04 PM
vc
Dec 22, 2005 06:58 PM
AgentUT
Apr 18, 2004 06:39 PM
missinghubcabs
Jun 25, 2003 03:41 PM
