motor problems (HELP)
Old Nov 13, 2004 | 11:25 AM
kentuckyprelude's Avatar
Default motor problems (HELP)
Ok when the car is idleing it seems to run fine,but when you go down the road and give it a little gas the car starts to jerk and it seems to studder and it backfires some times.And it don't do it at the same rpm.One time it barely made it up a small hill.Now I just put the motor back in I had it bored and sleeved and changed the compresion and ported and polished the head and new vemon injectors and it's supercharged.so can somebody help me.
Old Nov 13, 2004 | 11:39 AM
Hawkze_2.3's Avatar
Default Re: motor problems (kentuckyprelude)
Check timing, TPS, fuel pressure...
Did you get it tuned at all?????
Old Nov 13, 2004 | 11:44 AM
Default Re: motor problems (Hawkze_2.3)
timing looks to be good and the fuel pressure is like at 100pounds
Old Nov 13, 2004 | 11:49 AM
Hawkze_2.3's Avatar
lbs?...What is that in psi? Should be near 40-45 psi...probably more for your setup
Luvablexme
Jul 28, 2014 12:53 PM
punisher003
Dec 24, 2008 04:37 PM
mr. vang
Sep 28, 2005 12:37 PM
carblegal
Sep 12, 2002 12:47 AM
Vtec integra
Apr 27, 2002 08:59 PM
