full engine build for FI?
Old Nov 15, 2004 | 01:55 PM
ludegetsmwet's Avatar
Default full engine build for FI?
sorry if i posted this in the wrong place, but i just wanted to make sure that i am covering all needed parts to make this a complete build and if anyone has suggestions and tips. i plan on boring and honing the block along with port and polishing the head. I will be installing a FMAX T03/T04 ball bearing turbo kit on the rebuilt motor and will be running about 15 to 20lbs of boost at the track and 10lb on the street
pistons: JE forged Pistons and ring set (turbo applic)
rods: crower (stainless steel)
valves: crower(stainless or titanium?)
valve springs and retainers: crower
cams: crower (turbo applic)
sleeves: darton
head gasket?
bearings?
rod bolts: arp
Old Nov 15, 2004 | 02:02 PM
2kflamedlude's Avatar
Default Re: full engine build for FI? (ludegetsmwet)
Better send off your block to get it resleeved.
Old Nov 16, 2004 | 07:49 PM
PrettyLude's Avatar
send it to benson to do the sleeving, pm earl
Old Nov 16, 2004 | 08:05 PM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludegetsmwet &raquo;</TD></TR><TR><TD CLASS="quote">sorry if i posted this in the wrong place, but i just wanted to make sure that i am covering all needed parts to make this a complete build and if anyone has suggestions and tips. i plan on boring and honing the block along with port and polishing the head. I will be installing a FMAX T03/T04 ball bearing turbo kit on the rebuilt motor and will be running about 15 to 20lbs of boost at the track and 10lb on the street
sleeves: darton
head gasket?
bearings?
rod bolts: arp
1 - if you plan on running 15 - 20 lbs on the track and you are asking questions like this then you have no earthly clue what you are getting into.
2 - OEM Valves, head gasket and bearings.
3 - titanium springs and retainers.
4 - what CR pistons are you planning on running? just saying turbo app doesnt mean ****. i could have custom (turbo friendly composit) pistons made at 12:1 but that would be ******* insane.
EDIT: since you are in tucson, take your car over to Collective Racing. tell them that everyone at Honda-tech.com sent you over. ask for a guy that goes by the name of 2point6
Old Nov 16, 2004 | 09:18 PM
GOTNOS's Avatar
Default Re: full engine build for FI? (Shakes)
yea 2.6 knows his **** when it comes to ludes and boost.
Old Nov 17, 2004 | 07:33 AM
why would you think that i don't know what i'm talking about. I told you what boost i would be running to see if anyone would say don't use billet steel but rather titanium to handle that boost. just looking for opinions and do appreciate yours, but why would i run 12:1 compression more like 9:1. I guess that's why u said ******* insane. hey thanks for looking out. I do want to know why everyone says oem. do they offer good deals, and are there products any good. thanks for the help guys. right now i'm deployed in kuwait but once i get back i'll look him up.
Old Nov 17, 2004 | 01:01 PM
i know honda makes good products otherwise i wouldn't be owning a prelude but i've heard mixed opinions about oem and alc bearings main and rod.
Old Nov 17, 2004 | 01:27 PM
lildrgn2.0's Avatar
New User
Both bearing companies are good.
TI retainers
9:1 pistons
stock cams
Get the block sleeved
Maybe 3 angle valve job and a port and polish on the head while you are at it.
A good set of Cam Gears .. Unorthodox racing for me, but every one has their preference. Id stay away from AEM.
Dont forget management.
Probably a Turbo XS dual boost controller as well.
Old Nov 17, 2004 | 08:07 PM
2point6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludegetsmwet &raquo;</TD></TR><TR><TD CLASS="quote"> right now i'm deployed in kuwait but once i get back i'll look him up.</TD></TR></TABLE>
Get home safe and hit me up. I will be glad to help you in any way. If you can call my shop 520 296-2223. Hope to hear from you soon.
Old Nov 17, 2004 | 10:58 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludegetsmwet &raquo;</TD></TR><TR><TD CLASS="quote"> I do want to know why everyone says oem. do they offer good deals, and are there products any good.</TD></TR></TABLE>
When it comes to bearings and the hg, OEM has proven itself
time and time again even in high hp setups.
Remember, tuning is the most important key to a good setup
Old Nov 18, 2004 | 04:13 AM
lildrgn2.0's Avatar
New User
Default Re: full engine build for FI? (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
Remember, tuning is the most important key to a good setup </TD></TR></TABLE>
Amen brotha
bcr2005r
Dec 9, 2010 08:56 PM
teg_95
Jan 14, 2008 04:18 PM
1Quikgsr
Nov 8, 2007 08:18 PM
92eg6
Sep 23, 2006 06:15 AM
ludegetsmwet
Nov 17, 2004 07:36 AM
