Vtec stumble problem
Old Nov 8, 2004 | 10:20 AM
1point7db2's Avatar
Default Vtec stumble problem
I've got an H22A1 swapped into a CRX. Today while driving the car started to stumble sorta like you turn the key off and back on real fast, and then it would continue through the rpm range with no Vtec. What the hells going on? What should I check first? It is full of oil and up to operating temp when this happens.
Old Nov 8, 2004 | 11:42 AM
Elkins911's Avatar
Default Re: Vtec stumble problem (h22rexguy)
check your fuel pressure, how are you driving it when it stumbles?
Old Nov 9, 2004 | 08:46 AM
1point7db2's Avatar
Default Re: Vtec stumble problem (Elkins911)
Fuel pressure is 30-40 psi. I can be at any throttle position when I go into Vtec, but it does the same thing.
Old Nov 9, 2004 | 10:39 AM
staticrex's Avatar
Is the stumble at a certain RPM everytime?
Pleiadi79
Jun 12, 2008 08:22 AM
roadracer321
Jan 9, 2008 05:29 AM
salman
Mar 14, 2005 12:43 AM
speedunlimited
Sep 16, 2004 08:08 AM
CA6VTEC
Nov 2, 2003 03:17 AM
