Cap and rotor install...
Old Nov 15, 2004 | 09:48 AM
delguiner's Avatar
Default Cap and rotor install...
Hey guys, i was just wondering if there was a certain way or method to installing a new cap and rotor?
is it easy plug and play? or a little more complicated than that?
Thanks
JOey
Old Nov 15, 2004 | 09:55 AM
Hawkze_2.3's Avatar
Default Re: Cap and rotor install... (delguiner)
Remove and replace. The rotor will probably be very hard to get off, so what I usually do is hammer it slightly towards the engine to break it loose, then pull it off. Make sure you put the plug wires in the right place and put the screw for the rotor in tight.
Old Nov 15, 2004 | 10:00 AM
99_SH's Avatar
If havent assigned a "bitch" bolt for your car, the rotor bolt is a good place to start
Consider this your warning...
reymond23
Nov 23, 2007 11:06 PM
xstalkrx
May 21, 2007 04:34 PM
lostkoz
Mar 12, 2006 11:02 AM
ted
Jun 15, 2005 12:29 PM
machinehead
Oct 21, 2003 04:14 PM
