help on distributor!!! H22a
Old Nov 15, 2004 | 10:13 AM
sicklude94's Avatar
Default help on distributor!!! H22a
I did a h22 swap in my prelude and I had to use the h23 distributor and it went out so to get a new should I make sure it is for a vtec or does it not matter? Someone please help because i am wondering if that is why it went out because it couldnt handle vtec i dont know.
Ross
Old Nov 15, 2004 | 10:17 AM
accord-lude's Avatar
Default Re: help on distributor!!! H22a (sicklude94)
what year is your jdm h22a. there should be a code on the distributor itself check it out. im not sure but yest you have to get the correct one for your engine. or else it will be shorten out.
Old Nov 15, 2004 | 10:28 AM
SKDRCR's Avatar
Default Re: help on distributor!!! H22a (accord-lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord-lude &raquo;</TD></TR><TR><TD CLASS="quote">what year is your jdm h22a. there should be a code on the distributor itself check it out. im not sure but yest you have to get the correct one for your engine. or else it will be shorten out.
what?
The obd-1 udsm 92-95 distributors are the same, vtec or no vtec.
Old Nov 15, 2004 | 10:42 AM
GOTNOS's Avatar
Default Re: help on distributor!!! H22a (SKDRCR)
im using my h23 distro and its handling vtec fine no issues.
Old Nov 15, 2004 | 01:46 PM
93vtec's Avatar
Default Re: help on distributor!!! H22a (GOTNOS)
u can use either an prelude si or vtec distributor (h23 or h22) both of them would work... or u can simply just re-wire the jdm h22 distributor that came with your jdm h22 swap... it's easy.. all u have to do is re-wire it to external coil... they have instructions on preludeonline.com it shouldn't take no more than 30 minutes to do it...
Old Nov 15, 2004 | 04:14 PM
951dc5's Avatar
Default Re: help on distributor!!! H22a (93vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93vtec &raquo;</TD></TR><TR><TD CLASS="quote">u can use either an prelude si or vtec distributor (h23 or h22) both of them would work... or u can simply just re-wire the jdm h22 distributor that came with your jdm h22 swap... it's easy.. all u have to do is re-wire it to external coil... they have instructions on preludeonline.com it shouldn't take no more than 30 minutes to do it...</TD></TR></TABLE>
I rather stick with the vtec distri, saves the trouble..
Old Nov 15, 2004 | 06:14 PM
GOTNOS's Avatar
Default Re: help on distributor!!! H22a (Prelude951)
whats the trouble thou? the si and the vtec model distros are both the same about.
Old Nov 15, 2004 | 07:01 PM
v4lu3s's Avatar
RTFM
the h23 and h22 distirbtuor are the same....at least honda says they have the same part number...usually that means tehy are the same.
Old Nov 16, 2004 | 02:55 PM
951dc5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">the h23 and h22 distirbtuor are the same....at least honda says they have the same part number...usually that means tehy are the same.</TD></TR></TABLE>
They're the same but that rewiring part..damn i rather just buy the right one and just plug on connectors and go..
Old Nov 16, 2004 | 07:12 PM
v4lu3s's Avatar
RTFM
what rewiring part are you talking about?
Old Nov 16, 2004 | 07:17 PM
sicklude94's Avatar
Default Re: (v4lu3s)
i dont know what rewiring part he is talking about either.
Old Nov 16, 2004 | 09:55 PM
93vtec's Avatar
Default Re: (sicklude94)
lol... maybe he misunderstood wut i was sayin.. u don't have to rewire the usdm h22/23 distributors.... but i fu wanna use the jdm h22 internal coil distributor u have to rewire it to external coil.. which is very easy to do... and since u already have a jdm disty u might as well do it and save the money from buyin a new one...
Old Nov 17, 2004 | 06:09 AM
v4lu3s's Avatar
RTFM
last time i did hta ti left the external coiol plugged in and plugged in the internal coil distributor to the harness and drove off.
Old Nov 18, 2004 | 06:34 PM
951dc5's Avatar
Default Re: (93vtec)
by the way, does anyone know how to install a msd 6al on prelude since it's a external coil..i havent experience installin that but have on the crx internal coil.
ANd if it's external coil, is it good to just use the stock coil there cap with msd??
NukeeZoid
May 25, 2006 10:15 AM
NukeeZoid
May 24, 2006 09:05 PM
s2k_al
Feb 21, 2005 06:19 PM
ramikassab
Dec 20, 2004 12:57 PM
sicklude94
Nov 16, 2004 07:45 PM
