Ignition Wiring
Old Nov 9, 2004 | 05:53 PM
CivicSiDriver02's Avatar
Default Ignition Wiring
I was told by someone that you can wire a USDM H23 wiring harness to work on a JDM H22 engine with internal ignition coil. I was told to just cut the connector off that would nornally connect to the external coil on the H23 and solder the black wire to the black and yellow wire and just tie the blue wire away. Is this true? Thanks for your help!!
Old Nov 9, 2004 | 06:32 PM
Default Re: Ignition Wiring (CivicSiDriver02)
Does anyone know???? The car is done with the swap other than this part and I need to know what to do. Anyone???
Old Nov 9, 2004 | 06:43 PM
mgags7's Avatar
search on this, in the civic forums theres a write up on how to do it......h22a into ek/eg civic i think is the title name, its got an explanation in there.......use the same guidelines
i did this myself but i forget the exact wire colors and stuff, if you dont find anything i will go look on my car and ill be able to tell you....
Old Nov 9, 2004 | 07:14 PM
Default Re: (mgags7)
Hey thanks for the reply. I searched but came up empty handed. Do you think you could check your car for me so i know how to do this? Thanks a lot for the help!!
Old Nov 10, 2004 | 12:45 AM
ph8ed4life's Avatar
Default Re: (CivicSiDriver02)
you can also use your h23 dizzy and coil
rfslapshot1
Oct 16, 2011 06:54 PM
MikeLuder
Jun 29, 2009 01:47 PM
ASUJA
Jun 4, 2008 07:12 PM
flip1199
Sep 16, 2005 12:00 AM
BillClinton
Mar 15, 2005 04:14 PM
