memory and ignition kill
Old Feb 22, 2005 | 07:50 AM
cys19's Avatar
Default memory and ignition kill
I have this lever left to my driver's seat that says "memory." What does it do? I don't have an owner's manual.
Also, has neone ever installed an ignition kill before? If so, where can I get one and how do I install it?
Thanks.
Old Feb 22, 2005 | 08:10 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: memory and ignition kill (cys19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cys19 &raquo;</TD></TR><TR><TD CLASS="quote">I have this lever left to my driver's seat that says "memory." What does it do? I don't have an owner's manual. </TD></TR></TABLE>
Did you read the ******** thread at the top? You should of, or just search next time.
https://honda-tech.com/zerothread?id=934333
https://honda-tech.com/zerothread?id=926030
https://honda-tech.com/zerothread?id=866958
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Also, has neone ever installed an ignition kill before? If so, where can I get one and how do I install it?
Thanks.</TD></TR></TABLE>
You're talking about a kill switch. I don't know how to do it, but I've heard it's easy to do. It has something to do with the fuel pump. Goooooogle it or search archives.
Old Feb 22, 2005 | 08:27 AM
cys19's Avatar
Default Re: memory and ignition kill (Sticky Tires)
how'd u get those search results? i typed in memory and nothing came up.
Old Feb 22, 2005 | 08:30 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cys19 &raquo;</TD></TR><TR><TD CLASS="quote">how'd u get those search results? i typed in memory and nothing came up.</TD></TR></TABLE>
where it says Data Set, click on archived content.
Also, where it says Forum, select the PRELUDE forum.
Then click on search.
Old Feb 22, 2005 | 08:31 AM
kulrevon's Avatar
what kind of ignition kill. like a switch that wont let you start the car? or an alarm or what.
for the switch you can just splice into the ignition wire in the coloumn or the starter wire put in a relay on the normally open position. then set the switch up so when you flip the switch it throws the relay to closed. Thw car wont start unless the switch is on. hope that helped a little or just made you confused. You have to understand 12v systems sorry.
b18b1turbo
13
Feb 7, 2008 09:51 PM
mingus
Honda S2000
37
Jan 13, 2008 02:04 PM
si0385.
Dec 1, 2005 05:37 PM
AndyD
Mar 30, 2005 11:27 AM
Ponyboy
11
Sep 1, 2004 05:23 AM
