Which mark for TDC?
Old Feb 24, 2005 | 02:39 PM
SoSideways's Avatar
Default Which mark for TDC?
Curious, need a quick reply, but which mark should i use for Lining up TDC on my h22a1 with an automatic tranny? I've found the marks on the flywheel, the white dash, sideways T, then below that is a sideways W, and below that look to be the three marks for checking the timing, one red dash. Not sure which one to line up with, thanx.
Old Feb 24, 2005 | 03:01 PM
SKDRCR's Avatar
Default Re: Which mark for TDC? (SoSideways)
I believe the white dash is the tdc mark.
Old Feb 24, 2005 | 05:09 PM
Revi's Avatar
Default Re: Which mark for TDC? (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">I believe the white dash is the tdc mark.</TD></TR></TABLE>
Second that. Helms says White Mark is TDC....and we all know when the Helms speaks..........NO ONE QUESTIONS.
Old Feb 24, 2005 | 09:21 PM
LudeyKrus's Avatar
Default Re: Which mark for TDC? (Revi-Ra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revi-Ra &raquo;</TD></TR><TR><TD CLASS="quote">
Second that. Helms says White Mark is TDC....and we all know when the Helms speaks..........NO ONE QUESTIONS.</TD></TR></TABLE>
Funny story:
Me and JTCDudeman were swappin in a F22B into an auto H23 and the Helm's specs for the torque converter bolts seemed too tight: we ended up snapping two bolts, I believe, before trying something else.
Old Feb 25, 2005 | 08:22 AM
SoSideways's Avatar
Default Re: Which mark for TDC? (LudeyKrus)
Hmmm, thats odd, i read one place not to use the white mark. I just tried to line it up, and it still is out of time. It wont even start. It tries to but makes backfiring sounds out the intake mani. Hmmmm....
Old Feb 25, 2005 | 10:09 AM
LudeyKrus's Avatar
Well, a much easier way to get to TDC is to just pop out the spark plug from #1 cylinder, stick a long screwdriver or rod or something into the cylinder to sit on the piston, then turn the motor by hand until the rod goes to the top of the stroke and stops going up, but before it starts going back down.
Old Feb 25, 2005 | 10:20 AM
gerhard's Avatar
Default Re: (LudeyKrus)
A not so easy way to do it is to take the distributor apart and line up the CYP sensor with the tear dropped metal piece on the shaft.
When those are lined up, you are exactly at TDC.
IntegraTypeR
May 1, 2006 12:58 PM
civic_tuned
May 12, 2005 10:04 PM
bonta-kun
Jul 19, 2004 11:55 PM
turbob16
Jan 17, 2004 07:03 PM
