Changing To Manual?
Old Feb 28, 2005 | 01:50 PM
mr.newbie's Avatar
Default Changing To Manual?
well i have a 1999 Prelude i was wondering how much it would cost to switch it to manual?? as u can see by the name i am a newbie so yeah...what would i need for it?im plannin to switch it unless my dad wants the car n i'll take his civic 91 n do something with that yeah just wondering what would i need n for how much switch it to manual? thanks for the help!
Old Feb 28, 2005 | 02:04 PM
Dougs96SI's Avatar
Default Re: Changing To Manual? (mr.newbie)
Before you get flamed for asking a question that comes up every other day, i will attempt to answer/guide you on your quest for a clutch.
List of Parts:
Helms Manual (VERY IMPORTANT) Helm Inc
Transmissions Assembly (97+)
Trans mounts-side
Engine Mount-rear (rear is optional-the rear auto mount will work)
Flywheel and bolts
Clutch Kit and bolts
Clutch Master Cylinder
*Clutch Slave Cylinder
*Clutch Dampener
*Vehicle Speed Sensor (VSS)
*Reverse Switch
*Hydrolic Lines
*5spd Starter
Clutch Pedal Assembly
Brake Pedal Assembly
Shifter Assembly
Shift linkage
Auto ECU or 5speed ECU
5spd Intermediate shaft (half-shaft)
5spd Gauge Cluster (optional)
Cotter Pins (assorted sizes)
Assorted Nuts and Bolts
All this info and a "how to" came off of this site--> http://www.mazmo.com/zameoj/swap.htm
There is a lot more information in the archive, that you can search through by using the search feature located in the top right corner of your screen. Hope this helps, and Welcome to Honda-Tech.
Old Feb 28, 2005 | 02:05 PM
clemsoncb7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.newbie &raquo;</TD></TR><TR><TD CLASS="quote">well i have a 1999 Prelude i was wondering how much it would cost to switch it to manual?? as u can see by the name i am a newbie so yeah...what would i need for it?im plannin to switch it unless my dad wants the car n i'll take his civic 91 n do something with that yeah just wondering what would i need n for how much switch it to manual? thanks for the help! </TD></TR></TABLE>
You should search. This is too vague of a question. Could cost you upwards of $2000, but you never know.
xduB95preludeSi
Jul 25, 2014 12:32 AM
HYBRIDCIVIC007
Jun 3, 2011 08:23 PM
-jacob-
Transmission & Drivetrain
Oct 31, 2008 03:57 PM
LudeSi-93
Dec 26, 2002 08:04 AM
