Compression
Old Feb 22, 2005 | 12:47 PM
Unlimitationz's Avatar
Default Compression
Hey guys I just bought a 98 Prelude. But now it won't run. :cbaby:
The mechanic said that it had something to do with the compression.
Is this something I should be worrying about?
Is this fixable?
Help please. Thank.
Old Feb 22, 2005 | 01:46 PM
Kronn 98SH's Avatar
Default Re: Compression (AznUnlimitationz)
can you be slightly more specific?
Old Feb 22, 2005 | 01:56 PM
Default Re: Compression (Kronn 98SH)
I thought I was being specific...
The mechanic said that the cylinders is losing compression. They are onlt 50
Old Feb 22, 2005 | 02:11 PM
98vtec's Avatar
moderator emeritus
your rings prolly croked.
4.6LJeepXJ's Avatar
Compression is a VERY SERIOUS problem.... usually poor compression in a cylinder is due either worn piston rings, leaky valves, or leaking head gasket. Low compression = loss of power, stalling, irattic idle, and one ton of a shitty car. Any way you look at it you need an engine or a rebuild. I would run a dry compression test and a wet test to test the rings. if it isnt the rings, pull the head off and inspect the valves and head for cracks and anything else that may make it leak.Make sure you know what your doing with torque specifications and torque procedures for the head if you torque them down wrong you will make things far far worse for yourself. Taking out head bolts can cause the head to twist just by taking it off. Good luck.
Old Feb 22, 2005 | 02:14 PM
Greyout's Avatar
Default Re: Compression (4.6LJeepXJ)
have your mechanic do a leakdown test to isolate the problem.
Old Feb 22, 2005 | 02:28 PM
Default Re: Compression (Greyout)
Thank guys. Hope it's nothing too serious. Just bought this **** too.
Old Feb 22, 2005 | 02:58 PM
dmxsoulja3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznUnlimitationz &raquo;</TD></TR><TR><TD CLASS="quote">Thank guys. Hope it's nothing too serious. Just bought this **** too.</TD></TR></TABLE>
LOL anything that involves compression involves pulling some part of the motor if thats not serious to you
Old Feb 22, 2005 | 03:47 PM
PrecisionH23a's Avatar
Locked for a poor title.
zoom545
Nov 22, 2005 09:04 AM
boosted lude
Oct 21, 2004 04:06 PM
Droppedatbirth!
15
Feb 2, 2004 06:36 AM
foesicks
Jan 8, 2003 03:16 PM
