pcb ecu pinouts
Re: pcb ecu pinouts (kulrevon)
ya it is but i am not sure if it follows the regular obd2 scheme since it has that electric power steering, thats why i need the wires that are going into the pcb ecu so i can wire it to the obd1 p72
Re: pcb ecu pinouts (jdmhore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhore »</TD></TR><TR><TD CLASS="quote">ya it is but i am not sure if it follows the regular obd2 scheme since it has that electric power steering</TD></TR></TABLE>
i bet it follows the normal obd2 scheme and then they just used odd pins that wern't used before.
are you trying to wires the elctric power steering?
Re: pcb ecu pinouts (prelittlelude)
no i am not trying to do the electric power steering i am going to use my power steering pump off of my engine right now. so you think if i just get the jumper that will be all i need to do because i have the whole engine harness all the way to the ecu plugs and i am going to use the p72 obd1 so if i got the obd2a-obd1 jumper harness you think it would work perfectly?
you know if it is going to be the obd2b or the obd2a? i am not sure i think its obd2a so i can pull the wire scheme pinouts off line somewhere. o ya is this an accurate pinout chart?????? cuz it is the one i was going to use and i dont want anything frying http://www.hondaswap.com/forum...29360 , let me know thanks!
Re: pcb ecu pinouts (ek9h22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9h22 »</TD></TR><TR><TD CLASS="quote">can you used the pcb ecu for a h22 engine?</TD></TR></TABLE>
me wondering the same thing.....and isnt it obd2b?
Re: pcb ecu pinouts (eg6b0i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6b0i »</TD></TR><TR><TD CLASS="quote">
me wondering the same thing.....and isnt it obd2b?</TD></TR></TABLE>
save yourself the hassle and just get a p72 with hondata setup
vtecn8ive
07-18-2009 02:19 PM
raidacaipo
16
11-14-2008 11:23 PM
