Is transimission fluid changes normal for a 5spd
Old Feb 20, 2005 | 01:56 PM
hotstuffjsn's Avatar
Default Is transimission fluid changes normal for a 5spd
I'm having the car oil changed Monday and was wondering if I shoudl go ahead and have the transimission fluid changed while i'm there also. My car has 175, 000 miles on it. Is this a waste of money or is it worth the bucks? Please list pros, cons please.
Old Feb 20, 2005 | 02:28 PM
clemsoncb7's Avatar
Default Re: Is transimission fluid changes normal for a 5spd (hotstuffjsn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotstuffjsn &raquo;</TD></TR><TR><TD CLASS="quote">I'm having the car oil changed Monday and was wondering if I shoudl go ahead and have the transimission fluid changed while i'm there also. My car has 175, 000 miles on it. Is this a waste of money or is it worth the bucks? Please list pros, cons please.</TD></TR></TABLE>
First of all, why don't you just change your oil and tranny fluid yourself? Second of all, there are no cons to changing tranny fluid. It should be done every 3 or so oil changes and all it does is re-lube all of the gears and syncro. YOu will notice a lot better and smoother shifting after replacing tranny fluid. I would also recommend honda OEM manual tranny fluid.
Old Feb 20, 2005 | 04:32 PM
The Phil's Avatar
Default Re: Is transimission fluid changes normal for a 5spd (maxvtec7500)
change it as often as you can.
Old Feb 20, 2005 | 06:14 PM
eMpAtHy's Avatar
Default Re: Is transimission fluid changes normal for a 5spd (xthephilx)
umm, they recommend it every 100k miles or so, but if you have never changed urs. change it! go to a honda dealership and pick up 3 bottles of oem mtf fluid. 3 bottles should be suffice.
Old Feb 20, 2005 | 06:41 PM
kablamo's Avatar
Yes you should get it changed for the reasons that it will make shifts smoother, because it allows the synchros to work more effectively. I'd recommend you use the original Honda tranny oil, but there's various schools of thought on that.
either way, do it.
Old Feb 20, 2005 | 07:54 PM
five-0's Avatar
Default Re: Is transimission fluid changes normal for a 5spd (kablamo)
I do mine every three oil changes because I beat the **** out of her. It is important to take care of expensive parts.
Old Feb 20, 2005 | 10:18 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxvtec7500 &raquo;</TD></TR><TR><TD CLASS="quote">
First of all, why don't you just change your oil and tranny fluid yourself? Second of all, there are no cons to changing tranny fluid. It should be done every 3 or so oil changes and all it does is re-lube all of the gears and syncro. YOu will notice a lot better and smoother shifting after replacing tranny fluid. I would also recommend honda OEM manual tranny fluid. </TD></TR></TABLE>
some people dont have the time to change it themselves, just something to think about.
Old Feb 21, 2005 | 09:33 AM
shl76's Avatar
Default Re: Is transimission fluid changes normal for a 5spd (98vtec)
i was watching Best Motoring's VTEC club and they were interviewing one of the higher ups from Spoon (maybe the CEO) who shocked everyone on the program by stating that you should change your manual trans oil in your Honda EVERY time you change your motor oil because there is no filter for the transmission like there is on the engine.
after hearing this, i was thinking, true, there is no filter on the trans but also, there is no combustion either, so the oil can stay fresh longer in the trans than in the engine. however, the guy from Spoon did not expand more into this topic.
i am not going to question the logic of one of the greatest companies that modify Hondas..but I wil stick to once every 15k mi interval for now.
Old Feb 21, 2005 | 10:04 AM
Daemione's Avatar
Default Re: Is transimission fluid changes normal for a 5spd (shl76)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shl76 &raquo;</TD></TR><TR><TD CLASS="quote">after hearing this, i was thinking, true, there is no filter on the trans but also, there is no combustion either, so the oil can stay fresh longer in the trans than in the engine.</TD></TR></TABLE>
My thoughts exactly . . . .
If I were road-racing my car on a regular basis, fresh tranny oil would be a good idea to have in there as often as possible. Since I'm not, sticking to the factory recomended 60,000 mile interval (for severe conditions) is plenty often.
Old Feb 21, 2005 | 10:13 AM
Greyout's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shl76 &raquo;</TD></TR><TR><TD CLASS="quote">there is no combustion either, so the oil can stay fresh longer in the trans than in the engine. </TD></TR></TABLE>
A transmission has a lot more moving parts that interact with eachother in a much harsher way then the internals of your engine.
Old Feb 21, 2005 | 10:17 AM
EJ1 wilcox's Avatar
Default Re: Is transimission fluid changes normal for a 5spd (Greyout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout &raquo;</TD></TR><TR><TD CLASS="quote">A transmission has a lot more moving parts that interact with each other in a much harsher way then the internals of your engine.</TD></TR></TABLE>
Yeah but every time I change mine it still looks fresh and clean...
I change mine about twice a year or so and so far every time I've drained it the fluid looks brand new still..
I wouldn't change it more than a few times a year unless you are racing...
MTF is formulated differently than regular oil so it protects your transmission parts more effectively....
Old Feb 21, 2005 | 10:27 AM
Greyout's Avatar
Default Re: Is transimission fluid changes normal for a 5spd (EJ1 wilcox)
which reminds me - I posted the question somewhere else, but maybe someone here knows...
what is the optimum operating temp range for Honda MTF?
Whatislove
Honda Civic (2001 - 2005)
Sep 12, 2008 08:22 PM
aries331
Dec 1, 2007 01:13 PM
unichi
Jun 14, 2005 02:15 PM
professorman
Jan 12, 2003 06:40 AM
Gump
Jan 8, 2002 11:17 AM
