doing the rotors
Old Feb 28, 2005 | 10:00 PM
ixcryxblood's Avatar
Default doing the rotors
Im getting ready to replace my rotors. Can I do just the front or do i need to do all of them? Also anyone have any suggestions on which type i should get? I drive a 92 prelude
Old Mar 1, 2005 | 12:07 AM
prelude h_deuce_trey's Avatar
Default Re: doing the rotors (ixcryxblood)
you can do just the front. The rear is just for e-brake.
I suggest oem blanks from Auto Zone or Napa.
You should change the pads too while everything is off.
Old Mar 1, 2005 | 03:52 AM
Explorer22's Avatar
I would do this; get the rotors (Possibly machine them, because they won't be exactly right; but I'm sure you won't have a problem if you don't machine them), then get some synthetic grease, and some new brake pads.
Be sure to grease everything from your slide pins, craddle, back of pads, and caliper puck(s). This will help with any vibration and/or noise. ACDelco makes a brake grease that works very well and we use in our shop.
When replacing the rotors, you will want to replace the pads as well, because most of the time, the pads may be warn unevenly, and will cause problems with your braking system working to its full potential. Hope this helps.
-Drew
Old Mar 1, 2005 | 07:35 AM
silver97prelude's Avatar
I have Brembo blanks off Ebay($35) and I have no complaints. I hav'nt heard
anything bad about the Autozone blanks though...
Old Mar 1, 2005 | 07:53 AM
PrettyLude's Avatar
Default Re: doing the rotors (prelude h_deuce_trey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude h_deuce_trey &raquo;</TD></TR><TR><TD CLASS="quote">you can do just the front. The rear is just for e-brake.
You should change the pads too while everything is off.</TD></TR></TABLE>
rocket30004
Oct 24, 2006 10:44 AM
H2290
10
Jul 28, 2006 01:56 PM
reeder321
18
Aug 10, 2004 08:17 PM
::MYCORD::
Jul 11, 2004 03:00 AM
lke2drvgsr
Jan 31, 2004 10:11 PM
