MSD plug wires
Old Feb 28, 2005 | 10:48 AM
korndog's Avatar
Default MSD plug wires
What are you guys opinions on msd plug wires. Those who have ran them have you had any problems? Would i just be better off getting factory plug wires or ngk's instead.
Old Feb 28, 2005 | 11:08 AM
prelittlelude's Avatar
Default Re: MSD plug wires (korndog)
i have them, haven't had problems, but i thought there was a rumor floating around to stay away from them... never really found out why.. hmm
Old Feb 28, 2005 | 12:16 PM
PrettyLude's Avatar
factory or ngk is what i would use, no problem yet
Old Feb 28, 2005 | 12:28 PM
NeriVTEC's Avatar
I have the MSD ones and haven't had any problem at all, in fact I didn't even know there was a rumor about them.
Old Feb 28, 2005 | 12:29 PM
97Preludeguy's Avatar
Default Re: (PrettyLude)
I doubt you'll have problems with them. MSD is a quality name, and they make quality products. I run OBX 10.5 mm triple core wires, and they've been working fine for me, just in case you are looking for an alternative. I actually think they made my idle smoother, or it could just be the crack
Old Feb 28, 2005 | 01:58 PM
@ries's Avatar
the msd's don't stay on the distributor too well. you either have to zip-tie them or open up the connectors so the will grip better. other then that no major problems... but stock or ngk wires is what i'd recommend also.
Old Feb 28, 2005 | 02:03 PM
HONDA-2NR's Avatar
Default Re: MSD plug wires (@ries)
i run msd of my lude and they work fine for me
Old Feb 28, 2005 | 02:59 PM
Under_Pressure's Avatar
Default Re: MSD plug wires (HONDA-2NR)
I use them to, and I’ve noticed that they don’t stay on that good but they never have come off since I got them a year ago. Hey if you like them get them. There well made and perform well.
Old Feb 28, 2005 | 04:50 PM
five-0's Avatar
Default Re: MSD plug wires (92h22alude)
Well, as aries stated, they wouldn't stay attached at the distributor very well until I opened the terminal a little. Now they seem fine.
Old Feb 28, 2005 | 07:32 PM
stllrfast's Avatar
Default Re: MSD plug wires (five-0)
I don't know how you guys plug-in your wires to the distributor. I've never had a problem with my MSD wires. When you plug them in to the distributor you should hear each one make a nice click sound otherwise they're not installed correctly. Unless there's something wrong with the distributor itself internally.
Old Feb 28, 2005 | 07:46 PM
JDMAflac's Avatar
yup, mine are fine.
Old Feb 28, 2005 | 08:31 PM
Drag-Accord's Avatar
Default Re: (AznLuder704)
unless your making over 400+ hp there is absolutely no need for them. It's a waste of money when the stock ones work just as well.
I would get some stock Honda OEM Plug wires if i were you.
I use nology hotwires on my h22 drag car and they work good too. expensive but, quality isn't cheap.
Old Feb 28, 2005 | 08:44 PM
five-0's Avatar
Default Re: MSD plug wires (stllrfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stllrfast &raquo;</TD></TR><TR><TD CLASS="quote">I don't know how you guys plug-in your wires to the distributor. I've never had a problem with my MSD wires. When you plug them in to the distributor you should hear each one make a nice click sound otherwise they're not installed correctly. Unless there's something wrong with the distributor itself internally.</TD></TR></TABLE>
Drrrrrrr....
ub3rn00ber
13
Oct 22, 2012 10:23 AM
Boosted_JDM
Jun 14, 2007 07:15 PM
kevino002
Jun 8, 2005 11:05 PM
hybridb18
Apr 12, 2003 11:37 AM
