m2b4 trans
Old Sep 28, 2005 | 06:30 PM
jfish's Avatar
Default m2b4 trans
What are the two 1/4 inch rubber lines on top of the trans where the speed sensor is
Old Sep 28, 2005 | 06:33 PM
K-Spec's Avatar
Default Re: m2b4 trans (jfish)
are you talking about those two tubes that stick out near the vss? If so, i heard those are for the power steering...
Old Sep 28, 2005 | 06:40 PM
jfish's Avatar
Default Re: m2b4 trans (khalal538)
two rubber lines next to the speed sensor on top where the diff is. power steering? if so plug them up?
Old Sep 28, 2005 | 06:43 PM
92hondalude's Avatar
it goes into your vss to tell how much the power steering needs to work depending on the speed you are goin.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfish &raquo;</TD></TR><TR><TD CLASS="quote">if so plug them up?</TD></TR></TABLE>
??? did you take out your power steering?
Old Sep 28, 2005 | 06:46 PM
K-Spec's Avatar
Default Re: m2b4 trans (92hondalude)
do you know why the 5th gen trannies dont have this?
Old Sep 29, 2005 | 02:38 AM
jfish's Avatar
The motor is going in a 97 accord. what year trans is this? will this set off the c.e.l if not used.
Old Sep 29, 2005 | 09:26 AM
K-Spec's Avatar
no, it will not set off the CEL...you can either leave it open or closed, it really doesn't matter. I left mine open. the tranny is off a jdm 4th gen lude with LSD.
Old Sep 29, 2005 | 02:26 PM
jfish's Avatar
Thank you
Fred Demara
Jan 4, 2012 04:33 AM
viking-101
Dec 5, 2011 05:28 PM
kjlindgr
Jul 29, 2008 07:13 PM
burningwrek
12
Mar 29, 2006 02:55 AM
takeheed
Sep 22, 2002 05:59 PM
