ecu help
Old Sep 29, 2005 | 10:51 AM
draxxus07's Avatar
Default ecu help
im throwing codes 13 and 65... 13 is the baro sensor code but everyone says its a code for a faulty ecu, 65 is for a faulty prim 02 sensor OR a faulty ecu.... well i just put an o2 sim on the primary and still throwing the code and my car still runs like crap
so im guessing the problem has to due with the ecu, has anyone had any issues with these codes b4? if this is the case im just gonna hurry up and pick up hondata and hope that fixes the issue
Old Sep 29, 2005 | 11:11 AM
IHateJDM's Avatar
Default Re: ecu help (draxxus07)
o2 sims are made for the secondary o2. Its not smart to use one on the primary. That is more than likely why the car runs like ****.
Old Sep 29, 2005 | 11:27 AM
draxxus07's Avatar
well it was on the secondary o2, i looked at the code it was throwing and figured might as well try it on the primary since the code said it might have been a faulty primary... but wuld a bad primary o2 sensor cuz the car to run so bad?
Old Sep 29, 2005 | 11:35 AM
IHateJDM's Avatar
Default Re: (draxxus07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by draxxus07 &raquo;</TD></TR><TR><TD CLASS="quote">but wuld a bad primary o2 sensor cuz the car to run so bad?</TD></TR></TABLE>
yes it would. a bad secondary o2 doesn't change much, but a bad primary is definitely a problem.
andyvaj
May 2, 2007 06:28 AM
the jdmchop
May 23, 2006 11:26 AM
Lewie
Jun 30, 2004 11:33 AM
S13 slide
Jun 2, 2002 03:30 PM
