H22A distributor question
Old Sep 23, 2005 | 11:47 AM
MrLude1's Avatar
Default H22A distributor question
I just swapped in a JDM motor,tranny & used the JDM distributor. When we attempted to start it, it sounded 180 degrees out of phase. But, this distributor won't let us adjust timing, do I need to use the USDM distributor? It also sounded like it was running on only 2 cylinders...
Old Sep 23, 2005 | 12:01 PM
98vtec's Avatar
moderator emeritus
Default Re: H22A distributor question (MrLude1)
on what car
Old Sep 23, 2005 | 12:10 PM
MrLude1's Avatar
Default Re: H22A distributor question (98vtec)
My bad. '95 4th gen Prelude(OBDI). I did a full list of upgrades all at the same time: Skunk2 IM,TB,stg1 cams, headwork, etc....
Old Sep 23, 2005 | 12:43 PM
BB4vTak's Avatar
if your going to uses the jdm, dizzzy.. its internal coil.. so if your using a usdm wireing harness you nees to rewire it from the external coil... i just got done doing this and its not a huge deal.
Old Sep 23, 2005 | 12:48 PM
SpeedFreak77's Avatar
Default Re: H22A distributor question (BB4vTak)
Also according to the manual the H22 is designed so that the distributor can only go in one way so you can't put it in 180 degrees out of phase.
Old Sep 23, 2005 | 07:32 PM
MrLude1's Avatar
Actually, I used an MSD cap to help w/the external coil setup, but thanx 4 tha info, I didn't think I could flip the 180. Now, I just gotta figure out why she won't start.
Old Sep 23, 2005 | 07:40 PM
98vtec's Avatar
moderator emeritus
i just went through the starting problem process. Check your coil, get your ignitor tested, inspect your cap and rotor, make sure your coil wire has resistance via multimeter, make sure that the agc-s fuse is not blown. It is the number 4 position fuse in the fuse box behind the driver side left kick panel. Bottom row 5 to the right.
Old Sep 24, 2005 | 07:19 PM
cruzin89lude's Avatar
how many spack plugs do you have hooked up?
Old Sep 24, 2005 | 07:39 PM
MrLude1's Avatar
Default Re: (cruzin89lude)
Boston boy are U? j/k, Yeah, my spackplug wires are all hooked up, but no cranky....but thanx for the coil scenerio. We triple checked everything, but gotta look @ the fuse too.
Old Sep 25, 2005 | 11:25 AM
MrLude1's Avatar
Default Re: (MrLude1)
Finally figured it out boys. A bad wire from the ignition to the coil. Now she fires up, just can't stay on. We just have to adjust the throttle. This would of been so much smoother if I didn't break the bank & bolted up a bunch of aftermarket parts along w/the JDM/5-spd swap. Oh, well. Time to break her in!
xH22xTEGx
Apr 6, 2006 12:25 PM
fuckaBitch16
Mar 7, 2006 12:45 PM
aburn
Dec 11, 2002 02:27 PM
satan_srv
Nov 14, 2002 02:55 PM
H22CIVIC
Aug 9, 2001 05:36 PM
