oil?
Old Sep 28, 2005 | 11:01 AM
nickolas388's Avatar
Default oil?
i looked in the FAQ's but i couldnt find any information on what type of oil i should use, because i need an oil change. i have a 5th generation base model. should i go synthetic?
thanks
nick
Old Sep 28, 2005 | 11:05 AM
Hawkze_2.3's Avatar
Default Re: oil? (nickolas388)
Synthetic is always better if you can afford it. Lasts a lot longer, makes more power, lubes better, etc... I am currently using 10w-30 Mobil 1.
Old Sep 28, 2005 | 11:23 AM
oh ok so if i decide to get synthetic or not. its going to be 10w-30 either way. i heard of why synthetic is better, but i didnt know it makes more power. thats cool. how many quarts does the 5th gen lude take? assuming you have one.
Old Sep 28, 2005 | 11:52 AM
snowblind7x's Avatar
Default Re: (nickolas388)
I would assume 5...
Old Sep 28, 2005 | 11:56 AM
Jordans95si's Avatar
Default Re: (snowblind7x)
buy 6 to be safe....
Old Sep 28, 2005 | 01:28 PM
driftmaster04's Avatar
mine takes 6 with filter change... these things hold a **** load lol.
Old Sep 28, 2005 | 01:39 PM
K-Spec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickolas388 &raquo;</TD></TR><TR><TD CLASS="quote">oh ok so if i decide to get synthetic or not. its going to be 10w-30 either way. i heard of why synthetic is better, but i didnt know it makes more power. thats cool. how many quarts does the 5th gen lude take? assuming you have one.</TD></TR></TABLE>
the 5th gen takes about 5qts with filter change...once you go synthetic, there's no turning back (to conventional). Royal Purple or Mobil1 = but i think Royal Purple last longer.
Old Sep 28, 2005 | 02:02 PM
Default Re: (khalal538)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">the 5th gen takes about 5qts with filter change...once you go synthetic, there's no turning back (to conventional). Royal Purple or Mobil1 = but i think Royal Purple last longer.</TD></TR></TABLE>
I don't know who thought that up out of thin air one day but it is totally not true I went from regular to synthetic and back to regular and no problems at all.
Old Sep 28, 2005 | 04:49 PM
mkazm83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">...once you go synthetic, there's no turning back (to conventional). .</TD></TR></TABLE>
Thats false, get 6qts just in case.
Old Sep 28, 2005 | 05:29 PM
so its 10w-30 either way? does anyone use a different oil?
Old Sep 28, 2005 | 06:28 PM
mkazm83's Avatar
^^if youre going with 10-30, you might as well use 5-30. Make it a little easier on your motor at startup.
Old Sep 28, 2005 | 06:46 PM
Dougs96SI's Avatar
Default Re: (mkazm83)
I use 5W-30 because it says to right on your oil cap.
OEM specs are never wrong
Old Sep 29, 2005 | 10:54 AM
Default Re: (Dougs96SI)
thanks alot. i had a different oil cap when i baught my car so i didnt know what to put in lol. also, didnt get a manual with my 5th gen, but thats coming in the mail.
so ill use 5w-30.
thanks everyone
chaserz
Honda Civic (2001 - 2005)
24
Oct 4, 2008 03:27 PM
Nicksi7
33
Dec 16, 2006 08:39 PM
Jordans95si
Sep 2, 2005 07:45 AM
cookci
Jun 20, 2004 07:18 PM
kryptic
Jul 18, 2003 09:05 PM
