car problem, help!
Old Sep 26, 2005 | 07:52 PM
Fobstylez's Avatar
Default car problem, help!
My car runs and idles fine, but every once in a while, like a few times every few days, it just shuts off. No lights, it just turns off like you just turned the key off. I know honda has an ignition recall which sounds like this issue but my car has already been serviced. I dont know if much things that would cause this car to just die like this. I can be driving normal and it would just shut off, pop down the clutch, turn the key, and it shuts up fine. Can anybody help? I have an appt with honda sat but would like some feedbacks so i can try to fix it myself first.
Old Sep 27, 2005 | 07:56 AM
JMDh22's Avatar
Default Re: car problem, help! (Fobstylez)
Check your EGR (think its code 12) if you fix that usually that'll solve your problem.
Old Sep 27, 2005 | 07:57 AM
mgags7's Avatar
this thread(and its title)is worthless....
who would have thought that it was a car problem and that you needed help....
Old Sep 27, 2005 | 08:07 AM
iLude's Avatar
What about your ground wires? I've read of faulty grounds leading to this... try to check those
Krado
Dec 16, 2010 05:12 PM
AnAccordIsForever
Mar 19, 2007 12:45 PM
xmoua
Aug 4, 2006 05:47 PM
deviant94ex
Jan 2, 2002 05:30 PM
