code 43. where to start?
Old Sep 28, 2005 | 07:15 AM
chitownrida's Avatar
Default code 43. where to start?
ok i've been having this problem with the car bucking and missing every time i 1st start it when it is warm already and go to take off but normally it doesent throw a code... but yesterday
was driving to school going about 45 mph 5th gear then i go to accelerate a bit and the car just will not accelerate, it starts bucking and poping and the cel turns on.. code 43.... where should i start??
i have had this problem for a while, and seems like its getting worse and worse
(even before with the old 02 sensor)
btw
timing was checked on the flywheel last week was ok
02 sensor is only few months old (but not replaced with oem. its a bosch 4 wire)
Old Sep 28, 2005 | 07:32 AM
pentaq's Avatar
Default Re: code 43. where to start? (chitownrida)
I had the same. It's the fuzziest described CEL code in all. Try to put some injector cleaner into the gas tank and get on it.
Old Sep 28, 2005 | 08:43 AM
syntax.'s Avatar
yup, i battled the same code and never really figured it. when i tore the engine apart, two of the injectors looked pretty nasty so i assume they were the culprits all along. post up if you find anything deffinative
Old Sep 28, 2005 | 09:15 AM
steveobb4's Avatar
Default Re: (syntax420)
i think code 43 is fuel supply system, check your fuel pressure and have you done a tune up recently. could be something simple, always remeber the basics. good luck
Old Sep 28, 2005 | 10:56 AM
bgm93srv's Avatar
Honestly I had the same problem with my Bosch 4 wire O2 sensor. I don't know exactly why but they don't always seem to work very well in our cars, so I was told. Switched to an NTK and problem went away. Try a better sensor and I can almost bet it'll be fixed.
Old Sep 28, 2005 | 11:44 AM
oh i was also having this problem with the oem sensor too (when the car was NA)
ok. gonna start with injector cleaners/ and fuel filter.
keep you posted
Modified by chitownrida at 1:10 PM 9/28/2005
4g4dcruisin
23
Jul 23, 2012 04:55 PM
slowteg0bd1
Mar 4, 2009 09:13 AM
DC2_JAPAN
17
Jun 19, 2007 12:08 PM
EK_vzla
Oct 8, 2003 11:20 AM
