h22 type question
Old Oct 22, 2005 | 05:43 PM
218luder's Avatar
Default h22 type s question
hey guys i did a search about the type s and didnt find what exactly i was lookin for.
i have a 92 lude and lookin to do a swap soon and have my eyes set on the type s motor.
my questions are.
1. is this swap more difficult to do since its the type s
2. since its coming from the 5th gens, will the harnsses match up
3. odbII - odbI harness is needed
i have done some research but i only found limited info.
and if there is anything u guys would like to add or comment go ahead.
thanks
Old Oct 22, 2005 | 06:03 PM
Mad Hatter's Avatar
Default Re: h22 type s question (218luder)
type s is probably only difficult because its ODB2 and your cars ODB1 (im assuming). it also has ATTS and no lsd (unless its the SiR s-spec). if it were me, i would go with the jdm h22, since it comes with lsd and only has 15 or 20 less horses. its also much cheaper and easier to find. Whichever you choose...good luck with the swap
Old Oct 22, 2005 | 07:03 PM
EGmikeH22's Avatar
* B A N N E D *
you'd be waayyyyy better off doing type-s cams in a 92-96 H22A, they are stronger engines (bottom end) and with the type-s cams you get back most of the power difference, swap in type-s pistons and you're pretty much there, for about 2500-3000 less.
Old Oct 22, 2005 | 11:43 PM
218luder's Avatar
well thanks for the input guys thats all i was lookin for. wow i dont think i remember readin that the type s dont come with lsd. then again i just must have assumed it did. but thanks again guys
Old Oct 23, 2005 | 08:49 AM
EGmikeH22's Avatar
* B A N N E D *
a regular H22 is only a few hundred more with an lsd
so get that
Old Oct 23, 2005 | 07:32 PM
mgags7's Avatar
Default Re: (EGmikeH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGmikeH22 &raquo;</TD></TR><TR><TD CLASS="quote">you'd be waayyyyy better off doing type-s cams in a 92-96 H22A, they are stronger engines (bottom end) and with the type-s cams you get back most of the power difference, swap in type-s pistons and you're pretty much there, for about 2500-3000 less.</TD></TR></TABLE>
oh really....whats so strong about the older block??
the 98+ block is the one to with, because:
1)open deck = cooling +, and sleeving ease
2)55mm mains = stronger
to the poster: if you had searched, or used the link in the RULES on how to search effictively, you would have found out (1) the type s is atts (2) you will need to use your stock h23 or f22 engine wiring harness (3) you will NOT need an obd2&gt;1 adapter (4) you will have to wire up some sensors
use the search button...
ej84dr
Aug 16, 2010 09:18 PM
soclean1k_JDM
May 20, 2009 12:57 AM
WeekH22#2
Nov 8, 2005 07:13 PM
Slow CX
Jan 26, 2003 09:47 PM
Jin Yamato
Oct 26, 2002 12:45 PM
