vtec problem
Old Oct 15, 2005 | 12:14 PM
blusmke's Avatar
Default vtec problem
Ok i bought a 92-95 jdm h22 swap. I am having a problem with vtec engaging. I have a vfac and it said that my ecu is sending a signal. I checked with a test light at the silenoid it is good there. I put a wire from the batery straight to the silenoid and it is clicking. So i took apart the silenoid and cleaned it out. Still no vtec. I tried a thicker oil. More fuel, and now i am stumped. I was also woundering if anyone knew how small the oil passages to the rockers are. maybe i have some blockage some where. o and i have no cel
I am down to try any ideas thanks
Old Oct 15, 2005 | 12:20 PM
prelittlelude's Avatar
Default Re: vtec problem (blusmke)
https://honda-tech.com/zerothread?id=830163
Old Oct 15, 2005 | 12:45 PM
blusmke's Avatar
Default Re: vtec problem (prelittlelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=830163</TD></TR></TABLE>that is very helpful thank you so much. i will try the whole mechanical thing for now i have checked signal, wiring, and oil pressuure. Well for the pressure i would sure hope that at 6000rpm's and 20-50w oil that it would have enough oil pressure.
Old Oct 15, 2005 | 12:51 PM
if you bought an engine swap, ususally the mortors sit around for a while on the oil pan and are transported just sitting on the oil pan, make sure there are NO dents WHATSO EVER in the oil pan on the bottom.
Old Oct 15, 2005 | 12:57 PM
blusmke's Avatar
i know that it had been sitting around you should of seen the clutch. I didn't think that there were any dents but i will check it out carefully
Old Oct 15, 2005 | 12:59 PM
there is awlays a logicaly reason for vtec not working. the problem is either electrical or mechanical. electrical being the most common with swaps. mechanical relys solely on oil presure . if your motor was sitting around hopefuly there is no rust inside the motor..
Em1_coupe
23
Feb 20, 2008 07:11 PM
B18c1vicrx
Aug 18, 2007 05:28 PM
epak
Apr 22, 2007 01:31 PM
JDMb16ef
Oct 24, 2004 07:10 PM
endlesswinterco
Aug 15, 2004 09:36 PM
