h23a head problems
Old Oct 17, 2005 | 12:23 PM
Special_K23's Avatar
Default h23a head problems
I recently had a head job done on my h23a non vtec head. It is leaking oil out of the back of the head. It looks like a piece is missing!! The oil leaks out of a place that has B B B B on it!! It would seem as if a plug or bolt or something would go there if you can help me out please let me know something!!!!!
Old Oct 17, 2005 | 01:37 PM
herovueboi's Avatar
Is it leaking directly back or down into the side? I had a huge leak before but it was from my water pump. It was an OEM water pump wijth 202k and then it started spewing oil everywhere.
Old Oct 17, 2005 | 02:49 PM
prelittlelude's Avatar
Default Re: h23a head problems (Special_K23)
im not exactly sure what you mean, wipe away any oil and run the car and see if you can watch where its coming from , take a picture, a picture is worth a million words
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by herovueboi &raquo;</TD></TR><TR><TD CLASS="quote">Is it leaking directly back or down into the side? I had a huge leak before but it was from my water pump. It was an OEM water pump wijth 202k and then it started spewing oil everywhere.</TD></TR></TABLE>
it would be a cold day in hell before your water pump leaked oil, so it must have been something else.. maybe a balancer shaft seal?
Old Oct 17, 2005 | 05:40 PM
PirateMcFred's Avatar
Check your cam seals and make sure tha tthey are not worn, or ripped. Make sure that they are installed under the cam caps with Hondabond/Permatex/silicone too.
I had the same problem.
Pirate
speedciv
10
May 20, 2011 10:33 PM
mouab18c1
Oct 21, 2008 07:02 AM
caminSi
Jul 27, 2006 07:52 AM
DC4_MADMAN
Aug 4, 2005 07:47 AM
ECKOTYPER
Jan 28, 2004 01:17 PM
