obd2 to obd1 info
Old Oct 21, 2005 | 08:17 AM
01_prelude's Avatar
Default obd2 to obd1 info
ive got a 01 prelude what is needed to change the obd2 to obd1? ive heard that some say you need 4th gen injectors, and distrbutor. some say you dont. so icant find a correct answer. and would a p.72 be the best or p.28??? i ask this because they say the p.72 is off of a gsr which has dual butterflys is this true to??? can any one help me thank you!!!!
Old Oct 21, 2005 | 08:39 AM
The Weather Man's Avatar
Man - I know i shouldn't say this. But search seriously. That information is everywhere.
Start looking in the prelude essential links. That has a lot of good information.
Old Oct 21, 2005 | 08:42 AM
kulrevon's Avatar
Default Re: (TheKingPin)
if your running a stock ecu get the p13.
and yes this has been covered alot.
Old Oct 21, 2005 | 08:47 AM
01_prelude's Avatar
i found one post that made sence im just trying to get a solid answer
Old Oct 21, 2005 | 10:27 AM
nervous's Avatar
Default Re: obd2 to obd1 info (01_prelude)
You don't need anything other than a p72 or p28 and OBDI conversion harness. P28 has no IAB or knock board. P72 does.
Old Oct 21, 2005 | 10:59 AM
A Blue Lude's Avatar
Default Re: obd2 to obd1 info (nervous)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nervous &raquo;</TD></TR><TR><TD CLASS="quote">You don't need anything other than a p72 or p28 and OBDI conversion harness. P28 has no IAB or knock board. P72 does.</TD></TR></TABLE>
That's the answer you're looking for. A conversion harness + ecu is all you need.
Oh, and P28s can be modded to support IABs, although you don't see them all that often.
Old Oct 21, 2005 | 02:10 PM
01_prelude's Avatar
that helps better thanks so far guys
donvito#1
May 2, 2008 06:24 PM
viet_sensationz
May 26, 2007 06:33 PM
gsr_beats_20L_lsvtec
Mar 25, 2007 11:39 AM
finest_GSR
Oct 6, 2006 05:07 PM
98 blacksh
May 28, 2005 04:35 PM
