DIY intake?
Old Oct 19, 2005 | 12:00 PM
biggjimmy7's Avatar
Default DIY intake?
Hey whats up yall...ive got the itch to do something with my car and was wondering if there are any good intake diy write-up, or info for a 5th gen prelude. any and all info is appreciated....
thanks
B-ez
Old Oct 19, 2005 | 12:05 PM
Lewdin' Incognito's Avatar
Default Re: DIY intake? (biggjimmy7)
DIY writeup for an intake?
1. Remove stock intake.
2. Mount K&N filter directly to intake manifold.
-or-
2. Replace with $20 ebay pipe + filter.
-or-
2. Replace with $40 ebay CAI pipe + filter.
-or-
2. Get inventive and use PVC, flex-pipe, or a sweeper hose + filter.
Old Oct 19, 2005 | 12:52 PM
The_Sober's Avatar
Default Re: DIY intake? (Lewdin' Incognito)
if you wanna go really cheap...just pop the top half of your airbox off, make sure the filter is secure in the top half (a little tape around the edges works). Then move the filter/airbox top assembly about 1" to the side. Close your hood, and you're off.
Straight out the ghetto...
Old Oct 19, 2005 | 01:52 PM
biggjimmy7's Avatar
Default Re: DIY intake? (Sober_John)
haha na im not broke dude, not even close. nice inventive idea tho... i just like making things, especially for my car. i made a custom air ram for my old 1.8t which performed quite well, and without all the riff raff noise. i was looking at cold airs but their so fukin loud, i dont think i need any more tickets then i got, so i figured mayb a custom intake would do the trick
Old Oct 20, 2005 | 05:49 AM
The_Sober's Avatar
make a CAI w/ an expansion chamber 1/2 way up the pipe. it'll act like a resonator to keep things quiet, but will still flow just as much air.
Old Oct 20, 2005 | 06:10 AM
AnthonyG2003
Guest
Posts: n/a
Here, Go to this website...It will tell you everything you need to know. Next time just use the search button and you would have pulled up this same info because I have now posted this 3-4 times....
http://www.lightningmotorsport...l.htm
Old Oct 20, 2005 | 06:37 AM
maks's Avatar
Default Re: DIY intake? (AnthonyG2003)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnthonyG2003 &raquo;</TD></TR><TR><TD CLASS="quote">Next time just use the search button and you would have pulled up this same info because I have now posted this 3-4 times....</TD></TR></TABLE>
Maybe I'm blind, but where does that site show you how to make your own cold air intake?
Old Oct 20, 2005 | 06:43 AM
mgags7's Avatar
yeah, all that is is a writeup on installing one....
you can take the resonator off of the bottom of the intake, and just have it pull through the same airbox that is up inside the fender....or you could just pull the whole lower airbox out and cut enough of it so you can latch the filter in but the rest is open...
that one will be pretty loud though...i did that a few times...
da9pwnsu
Mar 26, 2006 02:07 AM
count_chocula
Mar 14, 2006 09:37 AM
Thirty-Nine
May 7, 2004 06:43 AM
