base shocks bolt up 98 SH
ive noticed some suspesion like tokico say 92-01 prelude excludinsg SH is the suspension diffrent on the SH?
example: http://www.optionsauto.com/pro...LK234
But none of the coilovers out say excludeing SH
example: http://www.optionsauto.com/pro...C008X
Re: base shocks bolt up 98 SH (ekim952522000)
its due in part because of the springs. the sh spring is different in diameter. so an after market shock that is make for a base cannot be used with the sh springs. but if you intend to switch out the springs and shock together than you are ok to use springs and shocks for the base, the the coil overs.
