problems and more problems.....
Old Oct 17, 2005 | 03:01 PM
Rudelude22's Avatar
Default problems and more problems.....
today i decided to change my fuel filter and along with that i installed a AEM rail & reg, and adjusted to 45psi liek it says. my neighbor who i just met today said he was awesome mechanic, i told him my problems, i said how i replaced the internal coil with an external, so we checked the timing it was way off...you know how the white line is supposed to match the lil > timing mark, it was higher than that, so i lined up the white line inside the > mark perfectly it idle fine and everythign i took it out for a test drive and bogged and hesitated like a mofu. It died in middle of road, so i pushed it out of the road, played with the timing is was off again, i musta bumped it when trying to tighten the 3 screws down, so i got it dead center again. Drove it back home and now it will only REV to 4k RPM....Driving home i realized i never jumped the ECU pin for CEL's. So if anyone could did i time it right or no? oh yeah its a 92 si--->JDM H22. any input is much appreciated. thanks.
Old Oct 17, 2005 | 03:18 PM
Rudelude22's Avatar
anyone know?
Old Oct 17, 2005 | 03:20 PM
prelittlelude's Avatar
Default Re: problems and more problems..... (Rudelude22)
this board runs alittle slow,
if the car ran fine before you or your friend touched it then try and make a readable list of everything you did before it was runing good.
yes that is how you set the timing, well you need to have the service pin connector jumped before you try and set thet iming.. even if you timing was a couple of degrees the car would run, there is something else you did.
Old Oct 17, 2005 | 03:34 PM
Rudelude22's Avatar
so what if i adjusted the dizzy without jumping the ECU, whats the going to do.
Old Oct 17, 2005 | 03:37 PM
Default Re: (Rudelude22)
nothing, it just isn't a very accurate way of checking the timing.
there is something else wrong with your car.
Old Oct 17, 2005 | 03:49 PM
Rudelude22's Avatar
it was throwing a code 43, o2/fuel system thats why i swapped out must of the system for fuel. but i havent seen the code in days untill yesterday i hit 6.5k and the motor cut out and it throw a code, i figured it might have been that one but idk, but now it wont rev past 4k and cant figure out what to do next.
Old Oct 17, 2005 | 03:52 PM
Jordans95si's Avatar
sounds like limp mode......
Old Oct 17, 2005 | 03:53 PM
what is the exact description for code 43 i forget, i thought it was just o2
Old Oct 17, 2005 | 04:05 PM
racericky's Avatar
well, how did you set the timing gun to 0 or 15. If you set the gun to 0 you should of been aligned up with the yellow mark, if set on 15 it should be with the white mark. As of the jumped wire it is only to keep the mark steady and not fluctuate whene testing, but the Prelude dosn't Fluctuate that much.
Old Oct 17, 2005 | 04:49 PM
Rudelude22's Avatar
there isnt a 0 or 15 mark on the gun just shoot i guess.
Old Oct 17, 2005 | 07:23 PM
Rudelude22's Avatar
bumpity bump anyone else ideas?
Old Oct 17, 2005 | 08:14 PM
JTCdudeman's Avatar
Master H Technician
You win...
Replacing the fuel rail with a much larger flowing one on a stock h22 when you already have a problem with a fuel system code being thrown will not help the problem at all... Is that not obvious?
Fix the problem before you go off modifying things such as fuel rail and regulators... Code 43 is fuel supply issues. thats where you should start your troubleshooting...
6.5k is limp mode as well...
You pissed me off once being ignorant, but I am going to help you so maybe you can learn something here... The CEL didnt cut on until you got there right? When do you use the most fuel? Does it sound feasible your having fuel cutout and thus, throwing the code? How sure are you the injectors are right? I would flow test them and hope you have the injectors that match up to the ECU.. Research peak and hold vs saturated...
Did you remove the injector screens and clean them?
Old Oct 18, 2005 | 04:43 AM
amckee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rudelude22 &raquo;</TD></TR><TR><TD CLASS="quote">it was throwing a code 43, o2/fuel system thats why i swapped out must of the system for fuel. but i havent seen the code in days untill yesterday i hit 6.5k and the motor cut out and it throw a code, i figured it might have been that one but idk, but now it wont rev past 4k and cant figure out what to do next. </TD></TR></TABLE>Find out if that is the same code as before then clear them before you do any more work to it. You don't want old codes coming up after you make changes.
EG-SIXV-TEC
Feb 11, 2013 01:31 AM
G2Crash
Mar 10, 2005 12:31 AM
civicdust
Oct 30, 2004 05:38 PM
integrasi
Jul 23, 2003 04:26 PM
EF8_SiR
Sep 20, 2002 08:45 AM
