switching the vtec head?
Old Oct 16, 2005 | 03:35 PM
msinsky14's Avatar
Default switching the vtec head?
i was wondering if it would be possible to swap the head of my si to a vtec...................what would this cost for the head and labor.........or is it easy enough for a beginner to install?
Old Oct 16, 2005 | 04:55 PM
PrettyLude's Avatar
do a search for lsvtec
Old Oct 16, 2005 | 05:08 PM
Shaggy's Avatar
I have also been looking into this swap. I'm not sure of the parts prices but it does not seem as if it would be a very easy job for a beginner to install. This thread has some useful information though. https://honda-tech.com/zerothread?id=510617 Hope this helps. good luck
Old Oct 17, 2005 | 06:28 AM
kulrevon's Avatar
Default Re: (Shaggy)
look in the essential links at the top of the forums.
Hybrid Engines - The Frankensteins
F23A Block/H22A1 Head (Accord SOHC VTEC/Prelude DOHC VTEC) by SamIam26
Additional F23/H23 Info by prelittlelude
H23A Block/H22A Head (Prelude DOHC Non-VTEC/Prelude DOHC VTEC)
F20B Destroking Hybrid by satan_srv
F22B2 Block/H22A Head (Accord SOHC VTEC/Prelude DOHC VTEC) by prelittlelude
F23A Block/H23a Head (Accord SOHC VTEC/Prelude DOHC non-VTEC) by PirateMcFred
I know they are not linked just go to the links page. I am not going to do all the work for you.
Old Oct 17, 2005 | 09:10 PM
petern101's Avatar
Default Re: (kulrevon)
wow the insanity
basically a h22 swap is cheaper and better
Old Oct 18, 2005 | 07:12 AM
prelittlelude's Avatar
Default Re: switching the vtec head? (msinsky14)
you will need the entire h22 top end, from the head to wiring harness to intake mani and exhaust. basically the only thing that would be left from the h23 is the bottom end.
Old Oct 18, 2005 | 10:48 AM
tarheelsoldier's Avatar
Default Re: switching the vtec head? (prelittlelude)
depending on if your car is wired for Vtec or not the wiring harness might not be needed ......
definitely need the rest just like prelittlelude said
mr_munro
May 25, 2021 08:27 PM
kylej420
Mar 31, 2017 09:17 AM
envious_accord
May 15, 2006 07:26 AM
jlteg
May 3, 2003 10:40 AM
TurboTeen16
Nov 4, 2002 11:40 AM
