Based on this dyno plot what vafc2 settings?
Old Oct 19, 2005 | 11:27 AM
tim.simpson's Avatar
Default Based on this dyno plot what vafc2 settings?
Hi
Had a dyno done a while ago on my 95 VTEC and the afr graph looks weak to me. I thought around 13->13.5 was where the power is. Take a look at the graph and tell me what settings you would try? My bro-in-law dynoed his 95 VTEC and got the same afr pattern. The cars are both stock motors with K&N panel and Janspeed cat-back.
I have left the stock vtec point (5k) and wanted to get the fueling better...
Old Oct 19, 2005 | 11:36 AM
prelittlelude's Avatar
Default Re: Based on this dyno plot what vafc2 settings? (tim.simpson)
are these two seprate runs with you messing with the vafc ?
Old Oct 19, 2005 | 11:41 AM
Default Re: Based on this dyno plot what vafc2 settings? (prelittlelude)
No. I had the dyno run done before the vafc2 was fitted. These are two runs performed after reseting my ignition timing back to stock. I had it advanced 2 deg to try gain somthing from the 98 octane fuel we get here in the UK. The red line with the better torque and afr is the run after the timing was set back at the distributor.
Old Oct 19, 2005 | 11:31 PM
Anyone? I need an idea of how much % fuel to add and where in the range based on my afr graph...
Please. Anyone?
Old Oct 20, 2005 | 10:08 AM
precord96's Avatar
you cant really add any fuel with a Vafc, pretty much all you can do is take fuel out.
Old Oct 20, 2005 | 03:27 PM
petern101's Avatar
Default Re: Based on this dyno plot what vafc2 settings? (precord96)
umm shouldn't you have posted the a/f ratio instead of dyno plots? its much easier to tune knowing your a/f ratio at rpms instead of how much hp you are putting down
or at least thats how i tuned my car: wideband + laptop + vafc is your friend
Old Oct 21, 2005 | 04:02 AM
Default Re: Based on this dyno plot what vafc2 settings? (petern101)
If you look, the 2nd graph is my afr plot. 1st sheet is power/torque and 2nd sheet is torque/afr...
Approximate from graph...
3.0k-->14.25
3.5k-->13.5
4.0k-->14
4.5k-->14.25
5.0k-->14
5.5k-->14.5
6.0k-->14.5
6.5k-->14
7.0k-->13
It appears to be weak from 4k-6.5k to me, I just don't know how much % to add on the vafc2?
Modified by tim.simpson at 9:18 AM 10/21/2005
Old Oct 24, 2005 | 04:57 PM
petern101's Avatar
i would say those are pretty good numbers
i tuned mine for a a/f ratio of about 13.5 - 14 so you are good unless you want more
Old Oct 24, 2005 | 05:14 PM
driftNWC's Avatar
bump
VtecKiDD
Oct 18, 2004 05:01 PM
brian2903
Jul 1, 2004 08:10 PM
int3gra
May 22, 2002 01:40 PM
