MAP. Best location? TB or IM
Would it be beneficial to run the MAP vacuum line to the TB or IM plenum? Or does this not matter? I know that both technically are in the plenum, but I want to know if being right next the the throttle will affect the readings differently. Thanks for any input. This is on a h22 obd1
Re: MAP. Best location? TB or IM
I dont think it matters really because some of them are mounted right on the throttle body while others are mounted on a bracket on the firewall.
