Is this part needed?(PIC)
Old Sep 2, 2012 | 12:04 PM
97accordbuildlx's Avatar
Default Is this part needed?(PIC)
sorry about blowing up the prelude forums the past week i just have a lot of little questions. this is the airbox thing that mounts directly ontop of the transmission mount on my 94 prelude h22. one of the lines i believe went to the intake manifold and the other line went to the intakes resonator box. is it needed? im just trying to clean up the engine bay:
Old Sep 2, 2012 | 04:07 PM
nemesis25's Avatar
Default Re: Is this part needed?(PIC)
Yes, it helps with cold starts I believe. I think it's called air bypass solenoid.
Old Sep 2, 2012 | 06:06 PM
yroachy's Avatar
if you are running a short ram or cai you don't need it as the resonator box in the bumper isn't doing anything...
Old Sep 2, 2012 | 08:25 PM
Hidenplanvew's Avatar
isnt that the part to open the butterflys in the intake manifold?
Old Sep 2, 2012 | 08:50 PM
the only part of the car im not 100%familiar with are the hose lines of of the intake system and what they do. but i think u mean the box that looks very similar to the one under the intake manifold correct? ill post a pic of it in a couple minutes.
Old Sep 2, 2012 | 09:03 PM
youre talking about this box correct? its just similar looking its not the same one.
Old Sep 2, 2012 | 09:04 PM
holmesnmanny's Avatar
There are two vacuum type boxes in your car. There is one that sits under the intake manifold and the other is where you said yours is. If that's where you got it, then you should just go ahead and keep it since it's obvious you're not running a CAI.
Old Sep 2, 2012 | 09:07 PM
http://www.hondapartscheap.com/find-.../AIR%20CLEANER
This should be yours. part 37
There is also...
http://www.hondapartscheap.com/find-...BING%20%282%29
part 12
Old Sep 3, 2012 | 10:49 AM
so i should keep it even though i removed the resonator box? because only the line to the intake manifold is hooked up
Old Sep 3, 2012 | 01:35 PM
yroachy's Avatar
If the box in the bumper is gone then ditch it and put a vac cap on the manifold where the line went.
Old Sep 3, 2012 | 03:11 PM
You can get a cap from a map sensor buffer hose in the 90-93 accords.
Old Sep 3, 2012 | 04:13 PM
yroachy's Avatar
Your local parts store or shop should have vacuum caps. Or just leave a little bit of hose and put a screw in it. Less neat but it works.
B_Money_H22
Nov 29, 2009 08:39 PM
AndyD
Nov 22, 2009 06:34 PM
Turbo-charged
Welding / Fabrication
Oct 11, 2005 04:45 PM
93 VTEC
May 2, 2004 07:22 AM
