What do I need ????
Old Sep 25, 2012 | 04:45 PM
N1NJ4574R's Avatar
Default What do I need ????
F22a stock from a 93 prelude s swapped with my new red top, aside from the ECU, transmission, motor and peripherals, what else will I need? If there's another thread I overlooked short me in that direction, otherwise bone stock to bone stock, what more will I need?
Old Sep 25, 2012 | 04:46 PM
10psiLsEf2's Avatar
Default Re: What do I need ????
A brain
Old Oct 2, 2012 | 01:14 PM
N1NJ4574R's Avatar
Originally Posted by 10psiLsEf2
A brain
How is that helpful you troll.
Old Oct 2, 2012 | 03:27 PM
yroachy's Avatar
Type s motor? How is it wired?
Old Oct 2, 2012 | 03:36 PM
snobordboy's Avatar
Moderator
If you are swapping to an H22, you are going to need an ecu, the correct wiring harness, and a stock exhaust manifold and downpipe, or header.
Old Oct 2, 2012 | 06:37 PM
10psiLsEf2's Avatar
i wasnt trolling bro! i meant a brain! Ecu,pcm,ecm.what ever you wana call it. i call them brains
Old Oct 9, 2012 | 06:42 PM
N1NJ4574R's Avatar
Totaly misunderstood. However, my post included 'comp', which I intended to mean computer/ECU. Will revise. Also, about the harness, are they expensive? easy to remove if I found a 'clunker'?
And yes my engine is a 2.2L 4cyl, f22a1, which is a non-vTec SOHC. I will be selling this engine and stock transmission with a brand new timing circuit(belt, tensioners and bolt, water pump, etc.) and replacing it with a Euro-R h22a1 Vtec DOHC and LSD transmission. I will be getting: engine and transmission combo, ECU, water pump, a/c unit, alternator, power steering pump, and DC headers.
Aside from the wiring harness what else will I need?
zackmith11
Honda Civic (2001 - 2005)
Jul 22, 2014 05:49 AM
melovesboost
Feb 9, 2007 04:06 AM
djsire
Mar 16, 2006 10:53 AM
00000xxx
Apr 9, 2005 07:05 PM
H22CL
Jan 2, 2004 07:48 AM
