tranny ?
Old Aug 22, 2012 | 03:49 PM
Pinarr's Avatar
Default tranny ?
I just replaced my clutch master cylinder, slave cylinder, clutch, and flywheel car was running great at first then all of a sudden my first and second gear went out couldn't seem to grab the gears hoping its not my transmission but and just something minor I have no experience with transmissions any help would be greatly appreciated
Old Aug 24, 2012 | 03:54 AM
bigblockh22's Avatar
Default Re: tranny ?
Cheak the linkage and the clips before you assume internal transmission problems. Also did you you the Honda transmission fluid?
Old Aug 27, 2012 | 05:31 AM
Pinarr's Avatar
Yea I used honda manual transmission fluid. Can the linkage become loose when dropping tranny? And if so how would I go about fixing that
Old Aug 27, 2012 | 06:04 AM
razorlude's Avatar
bleed ur clutch?smooth engagement during cold n hot ?pedal feel during hot and cold?
i just done almost the same thing like what you did last month n i got clutch slip when hard revving at 5th after some hot run.complete flush out the clutch fluid with some fresh dot4 + pedal height adjustment and it's all good now.
Old Sep 7, 2012 | 02:44 PM
Pinarr's Avatar
Yea did the same and afterwards felt a lot better
Old Sep 8, 2012 | 05:03 PM
crazes's Avatar
Moderator
Is this this all on the same car?
Old Sep 9, 2012 | 12:42 PM
Pinarr's Avatar
Yea all on the 97 lude sh finally works perfect after I flashed the system
Old Sep 9, 2012 | 07:52 PM
crazes's Avatar
Moderator
The reason i ask is because u posted 3 seperate threads about issues with the car. You might want to look at it all in one thread. So if i am not mistaken all these issues are on the same car you have
Old Sep 10, 2012 | 11:14 AM
Pinarr's Avatar
Oh the other problema are resolved saids it on there I've removed them.don't know why it would show up
koulninja
25
Mar 5, 2012 05:42 AM
hondasi94
Honda S2000
13
Apr 3, 2011 07:42 AM
Shiftandgo
Oct 5, 2008 09:57 AM
hialeahzbg
26
Jun 7, 2006 04:31 AM
es_squared
Sep 21, 2004 08:10 PM
