H23a Timing HELP!!!
Old Aug 10, 2012 | 07:46 PM
hondaaccordf23's Avatar
Default H23a Timing HELP!!!
So I have been getting frustrated with the timing belt I've lined
up everything but then when I put everything back together and start the
car I hear a whining from the timing area like as if its not tight enough or it's pushing up against the valve cover
I don't know what it is or what to do I need help please and thank you
Old Aug 11, 2012 | 12:14 AM
PilotOnDubs's Avatar
Default Re: H23a Timing HELP!!!
belt too tight? tensioner worn?
Old Aug 11, 2012 | 06:55 AM
I think I'm just going to swap for a manual tensioner
Old Aug 12, 2012 | 10:36 AM
bigblue7t6's Avatar
Usually a timing belt whining is a sign of being too tight
Old Aug 13, 2012 | 07:17 AM
didn't seem like the belt was tight there was still some play, so really the only belts that had no play was balance belt and serpentine belt
Old Aug 17, 2012 | 11:25 AM
catchdz's Avatar
my **** did the same thing for like the first 1000 miles then it went away just change the the manual tensioner, the belt needs to stretch a little give it time
Old Aug 17, 2012 | 11:48 PM
if the balancer belt had no play, it might be too tight cause the bearing to whine
Old Aug 18, 2012 | 04:21 AM
sigsr01's Avatar
Yes this is the way. Its turns out to be easy to convert it. It looks complicated from pictures until you actually does it.
Old Aug 18, 2012 | 09:12 AM
Ok sounds good thanks everyone Ill try to loosen the balance belt a little a see what happens
Old Aug 19, 2012 | 09:40 AM
you may have to replace one of the beaings/pulleys as the tight belt may have stressed it
Old Aug 19, 2012 | 10:04 AM
what type of bearing and is it pretty easy to get to
Old Aug 19, 2012 | 10:05 AM
its more when I brake btw is when I hear a noise
TheCrimsonGhost666
Oct 10, 2010 01:10 PM
airikkCRX
Apr 2, 2010 08:29 AM
slide inside
Oct 22, 2009 09:25 AM
Imprezn
May 6, 2003 01:36 PM
