engine shaking
Old Oct 11, 2012 | 07:09 AM
nchonda01's Avatar
Default engine shaking
Hi erveryone i was wondering if anyone know about my proplem or have had it before on there prelude?
i have a honda prelude 2001 atts h22z1 and the proplem is that after ive put on a heavy duty clutch and a liten flywheel on it my motor starts to shake when u slowly let go of the clutch does anyone have a clue im thinking it mite be the fylwheel but not to sure any help??? cheers
Old Oct 11, 2012 | 07:21 AM
snobordboy's Avatar
Moderator
Default Re: engine shaking
Sounds like chattering with a lightweight flywheel, and improper break-in on the clutch.
To get it to go away you may need to pull it out, get the flywheel skimmed, and re-install it, and break it in properly. My also be worth going to a heavier flywheel for better driveability.
Old Oct 15, 2012 | 03:05 AM
nchonda01's Avatar
do you know how much would it cost for the machanic to do that kinda work?
Old Oct 15, 2012 | 04:55 AM
yroachy's Avatar
Depends on the mechanic and their hourly rate... I think book time to change it is around 6 hours. If you can remove and install it yourself, it should be 50$ or so to machine the flywheel. If you had a shop do the initial install go back for possible warranty. However you may have a hard time if you supplied them the parts...
Old Oct 15, 2012 | 01:48 PM
crazes's Avatar
Moderator
this may sound dumb but you are giving it throttle pedal in relation to clutch release?
Old Oct 15, 2012 | 05:13 PM
Livinjdm559's Avatar
I want to know the same question. I had a heavy duty clutch on my gsr and it would shake a little bit if I didnt give it more gas than usual. The clutch, throwout bearing and flywheel were all ok. I called ACT and they stated it was a normal occurrence with a 6 puck.
check this thread out https://honda-tech.com/forums/forced-induction-16/clutch-chatter-6puck-1741110/
Ralleh
Honda S2000
11
Oct 13, 2009 05:40 AM
nijia555
Aug 22, 2006 02:06 PM
Naturally Aspirated
21
Aug 10, 2004 06:51 PM
Kamin
Oct 21, 2001 03:14 PM
