Help with Climate control.... bad!!!!!!!
Old Apr 18, 2006 | 07:53 PM
H22-VTEC's Avatar
Default Help with Climate control.... bad!!!!!!!
The climate control/ sparatic A/C fix it thread on another forum said to dismantle all this stuff and look at the climate control motherboard (big computer chip) and find the green plug. Then to flip it over and look at the solder (sp) points and to touch them up using a soldering stick. (they said to do this because the ones on there are cracked causing my stuff to not work properly. I did this and plugged it all back up. Nothing happend at all. The blower fan didn't turn on or anything. Nothing as far as the climate control and a/c works. I took it all apart and looked at my solder points. A few of them seemed to be overlapping each other so i went through and made sure all my points were not touching. I plugged it all back in and still nothing works.
What is wrong? I cant seem to figure it out. Did i mess somthing up soldering?
any info on this would be great!
Old Apr 18, 2006 | 08:48 PM
Siegfried's Avatar
Default Re: Help with Climate control.... bad!!!!!!! (H22-VTEC)
Check the sensor on the condenser, unplug it and bridge the connector and put your A/C ON, if it works then change the sensor.
If it still doesn' t work it can come from the A/C Relays on the driver/front side.
Old Apr 18, 2006 | 08:49 PM
Silver Surfer's Avatar
are you talking about the usdm or jdm climate control?
and 4th gen or 5th gen?
i have my 4th gen usdm unit that i will sell you pretty cheap if yours is not working
Old Apr 19, 2006 | 06:24 AM
H22-VTEC's Avatar
Default Re: Help with Climate control.... bad!!!!!!! (Siegfried)
what sensor are you talking about? How will i bridge it? and where exactly are the relays on the driver side. I want to check this stuff out before i buy a new one.
usdm 4th Gen
Old Apr 19, 2006 | 10:42 AM
Siegfried's Avatar
I don' t remember the name of the sensor but it's located on the condensor, at the bottom on the passenger side.
When I put my JDM climate control, my A/C wasn' t working because one wire was missing, I think it was the wire that was sending a signal from this sensor.
For the relays here's a pic from another topic, you should check if none of these have a problem, maybe it can keep the A/C from working if one is defective.
Old May 1, 2006 | 05:03 PM
H22-VTEC's Avatar
Ok i just got my new climate control today...plugged it in.....still nothing!!!! It has to be somthing else i had to have blown a fuse somewhere! I checked under the hood and under the driver side dash and nothing to my site is blown. What else is there to do!
speedfreek128
Feb 19, 2009 10:06 PM
1992HB
Feb 11, 2006 05:34 PM
Echelon
Jan 23, 2004 06:24 AM
