Vtec messing up
Old Apr 25, 2006 | 09:21 AM
slammed_92_accord's Avatar
Default Vtec messing up
Ok...This is a wierd problem...Not all the time but sometimes when ever i let vtec kick in my car will just shut off....and if i'm rolling and pop out on the clutch the car will still run but when i give it gas it bogs down and wont go n e where... Everytime it's done this i have jiggled the vtec soliniod and the wires and it will start...What is the problem?
Old Apr 25, 2006 | 11:22 AM
syntax.'s Avatar
Default Re: Vtec messing up (slammed_92_accord)
any cel's?
even if the ecu loses signal from the vtec solenoid it should cause the car to stall, vtec would just disengage.
Redo all the connections at the vtec solenoid, something must be loose. But i think you have a bigger issue than just the vtec solenoid because of the stalling, bogging etc.
Old Apr 25, 2006 | 03:28 PM
The ecu isn't throwing any codes.. Like what kind of bigger issues do u think it could be? I did a swap in my accord...i put an h22a in it... how is the vtec engaged? By oil pressure? or what?
Old Apr 25, 2006 | 03:31 PM
The Weather Man's Avatar
Default Re: (slammed_92_accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_92_accord &raquo;</TD></TR><TR><TD CLASS="quote">The ecu isn't throwing any codes.. Like what kind of bigger issues do u think it could be? I did a swap in my accord...i put an h22a in it... how is the vtec engaged? By oil pressure? or what?</TD></TR></TABLE>
How did you wire up the vtec?
Vtec has a few different parameters that allow it to come on - i don't feel like listing them right now - because i don't think that they will help you at all.
BUT, make sure the solenoid "screen" is clean and just make sure your connections are correct. give us a list of the ecu pins you connected vtec to.
Old Apr 25, 2006 | 06:29 PM
johnlude85's Avatar
i would try a different ecu. p28 chipped and socketed, plug and play $138 shipped. http://www.phearable.net thats where i got mine from
Old Apr 27, 2006 | 07:46 PM
i used pins...A4(vtec soleniod) And D6(Vtec oil pressure swith) And D3(Knock sensor)...btw....will the knock sensor cause my rev limiter to kick in at a lower RPM than it should?
92H23VTEC
Nov 25, 2007 06:49 PM
lmiguelvv
Oct 19, 2004 06:55 PM
97dc2
Sep 23, 2004 12:00 AM
DXDOHCVTEC
Jul 29, 2004 10:34 PM
Master23
Jul 8, 2004 10:25 AM
